Posts: 1.3K,
Visits: 80.0K
...and two extra leafs in the spring pack (total of 7) so as I found out, passenger car U bolts are too short to use on the wagons! Rono
Ron Lane, Meridian, ID
Visits: 497.8K
55 and 56 TBirds came with the Dana 44. As an added bonus, they had factory lowering "blocks" to make the Tbirds sit lower. I believe the length was the same as the sedans.
Posts: 1.9K,
Visits: 194.9K
At least on the 55 birds I've had, it's actually the perches (if that's the right word) that are different. The one back in the 60's needed lowering blocks when I put the wagon rear end in. Don't know about the u bolts. The wagon rear end was removed with a torch. I do remember having to get the lowering blocks to make the original u bolts work. I hadn't noticed before.
The one I have now had bad welds on the perches. Just figured it was a Monday production job. But when I went to replace the bearings, it had truck axles, and needed the larger bearings. I figure the rear end had been replace somewhere along the way. Still, it was a better job than the piece of plywood under the floor, so the wood screws could hold the gas pedal down.
Visits: 12.3K
Did the 55 and 56 birds really com with a factory lowering block?
Vic Correnti
Posts: 1.3K,
Visits: 9.2K
The pads were much taller on the birds than the passenger cars which act as lowering blocks, but they were welded to the rear housing so not really a removable lowering block.
-Gary Burnette-
