Fuel Pump Ponderings
Posted By Bill Childs 11 Years Ago
Bill Childs
Supercharged (196 reputation)Supercharged (196 reputation)Supercharged (196 reputation)Supercharged (196 reputation)Supercharged (196 reputation)Supercharged (196 reputation)Supercharged (196 reputation)Supercharged (196 reputation)Supercharged (196 reputation)
Posts: 67, Visits: 472
Hmm, I wasn't aware of the FE interchangability. So the attachment and the pump lever are identical? I had heard horror stories of some later pump levers not working properly because they were not identical in shape and size to the original.
Bill C
http://forums.y-blocksforever.com/uploads/images/61bc0a7f-ca1c-4ce4-b1f2-4b5b.jpg
Drag it home, figure it out.
Riz
Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)
Posts: 177, Visits: 4.4K
+1 for the FE 390 fuel pump. Easy to find and work right out of the box. If you don't need concours type matching parts a lot more economical for a build and bolt right up.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
GREENBIRD56
Posts: 1.7K, Visits: 102.7K
There are pumps for a 390 FE truck engine that have a canister style fuel filter screwed onto the bottom of the pump. I'm a believer in that type of filter - lots of capacity for crud and lots of fuel flow is possible, easy change out / clean-up too.
Bill Childs
Thanks for your input Steve. I'm thinking my engine will be closer to 240 - 250 hp max (stock heads, bore .080 over, 265° cam)?. It'll be a driver with the vac secondaries set so they only kick in when the pedal is mashed. Probably running about 320 or so cfm primaries almost always. I guess I'm hoping and wondering if a stock fuel pump will do the job. Any experience out there with a similar engine build and stock fuel pump? Thanks.
Bill C
GREENBIRD56
The mechanical pump for a 428 Police interceptor is a great choice for the engine equipment you describe. Just right to support 300-330 HP. The Holley brand 80 GPH pump for the FE engines is pretty much identical - delivers over 30 GPH at 4.5 psi.
Bill Childs
Hi guys. Gettin' real close to actual build time for my 292. Senior Mummert has been real helpful sending a bunch of tasty parts and keeping me on the right path to my goal. Gathering the last bits and pieces and was wondering what the good word is on fuel pumps these days. Are some more reliable than others? Will a stock style fuel pump be fine for my mild build with Mummert intake and 600 cfm Quickfuel carb? Any thoughts or wisdom on this is much appreciated.
Bill C
