55 Ford Running Hot?
Posted By Half-dude 11 Years Ago
Half-dude
Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)
Last Active: 7 Months Ago
Posts: 229, Visits: 11.3K
charliemccraney (9/30/2015)
180 should be about perfect.  160 is too cold.  The thermostat is not your problem, assuming it is working correctly.  You can check that in a pot of water, as  you bring it to a boil, or with a heat gun and infrared thermometer.
I ended up installing a 170 degree NAPA #6 thermostat. For the most part the gauge is staying right in the middle of the gauge or just about 3/4ths the way up at it's hottest. So it seems like my old thermostat was the problem as 3/4 or over was right where it used to sit by default. I think that old thermostat that was rated 180 actually didn't really open till 185/190, I actually did the boiling water test on it.
