Something that is bugging me.
Posted By lovefordgalaxie 11 Years Ago
lovefordgalaxie
Supercharged (388 reputation)Supercharged (388 reputation)Supercharged (388 reputation)Supercharged (388 reputation)Supercharged (388 reputation)Supercharged (388 reputation)Supercharged (388 reputation)Supercharged (388 reputation)Supercharged (388 reputation)
Posts: 269, Visits: 1.0K
Thanks guys.
I didn't measure the vacuum on the intake, so I don't have that info.
On the vale springs, two of mine were shot, so I ordered a new set, and when it arrived it was the double springs. I installed it when rebuilt the engine. Figured it wouldn't be a bad thing to have since I use oil with high ZDDP. I wanted to go with a larger cam, but ended using the E-4. I didn't loose too much of the low end torque, as the car is very heavy (same body as a '66 Galaxie four door sedan), and my town has a lot of hills.
The idle is not exactly rough, it has more vibration than stock. The kind you can feel on the floor pans if you pay attention to it.
Both motor mounts, and the transmission mount were replaced with new parts back in 2010.
Friend of mine even put the guilt on my exhaust, that is dual with glasspacks.
The last mufflers I had when the engine was stock was a pair of Thrush Welded mufflers. I replaced them short after rebuilding the engine as they were too quiet...
This is how she idles:
Túlio Lazzaroni "FORD", Florianópolis SC Brasil.
'74 Ford Galaxie 500 292 V8
'98 Chevrolet S10 4.3 V6
'01 Ford Focus 1.8 Zetec
It is larger than most factory cams so it could have a little more rough idle.  Shouldn't be too bad, though.  What is the vacuum?
Rono
Posts: 1.3K, Visits: 80.0K
I'm sure you will get a lot of responses from more knowledgeable people then me, but I am wondering why the double valve springs? I don't believe the E4 cam has that high of a lobe lift to require that.  Did you have double valve springs installed before you rebuilt the motor?
regards,
Rono
Cliff
Posts: 906, Visits: 13.9K
Hi, I had that problem a long time ago and after a lot of work I changed the motor mounts (advise from an old man, now I am an old man) the rough idle went away (hard old mounts).
Cliff
lovefordgalaxie
Question Posted 11 Years Ago
Hi guys,
I have something that is bugging me for some time now.
When I rebuilt my 292 back in 2010 I installed a Isky E-4 cam. The car runs great, and even tough at the time I installed the cam out of the box, without deepening the oil groove, the engine has great oil flow to both heads.
The thing that buggs me is the idle. The car never had the same idle it had when all stock. I was told the E-4 is not enough to alter the idle (not that I wouldn't install it because of that) but my engine doesn't idles as smooth as before. Along with the cam, the engine also has double valve springs, and 1,54 rockers. When all stock she had the lower ratio rockers.
Valve lash is correct, the carburetor is good (Autolite 4100), the car has no ignition problems, and drives super well, with no hesitations, flat spots, and has lot's of power. The problem is just the idle that is more vibrant than a stock engine.
My fear is having messed something out when rebuilding the engine.
For you guys with more experience on comparing cams, is the E-4 enough to change the idle?
Other than that, I've put more than 20 K miles on the 292, and it uses no oil, has more than 30 PSI of oil pressure idling at 750 RPM hot, and has a little more than 60 PSI on highway.
What do you think??
