CVF racing have pulley specs online. The bolt pattern and pilot diameter is not limited to Ford, so you have lots of options.
http://www.cvfracing.com/Something to keep in mind is how the pulley diameter affects the pump. Everything else the same, smaller pulley = higher pump rpm and larger pulley = lower pump rpm. I've only found one article about pump rpm and it is indicated that 7000rpm is a max for racing and for the street, you want it at least turning as fast as the crank. Source:
http://stewartcomponents.com/index.php?route=information/information&information_id=8. With that in mind, for racing the smallest water pump pulley you want with the stock damper pulley, which is about 6 5/8" is about:
5.3" for a 5500rpm shift
5.7" for 6000rpm
6.2" for 6500
Formula, (shift rpm x crank pulley diameter) / 7000
Another thing to consider is with a smaller pulley, and therefore higher pump rpm, more power is required to turn the pump so you don't necessarily want to pick the smallest pulley.
So for street / strip, you want something no bigger than the crank pulley but no smaller than that required for your expected shift point to keep pump rpm below 7000.
