Outlaw56
Visits: 26.9K
I just read a very extensive post on the Summit 4100 Replica over on the FTE Forum. From what I gathered, you can get kits for that carb to build it up, but you cant get kits to build it down. Since I consider a stock 272 on the down side, along with my understanding the Summit 4100 Replica is on the rich side...........Im thinking it might be a little too much carb for my application. My other concern was the terrible gas mileage one member got with serious time and energy put into making that carb work for him.Perhaps the Summit 4100 Replica is a better application for the beefed up 272's, or 292's with option of kits to build up? The other thing that got my attention is the allegation its made in China?
Outlaw56
Visits: 26.9K
Whats the difference between a Holley 525 Street Demon Jr and a Holley 570 Avenger? Is one better suited than the other for a stock 272 with a post 57 intake and newer distributer? Keep in mind all I know about carburators is where the mount on the engine. Never rebuilt one or did any "tuning". I have the Edelbrock 500 Performer that is going into a 292 that will be built up towards a 312 if I can collect the parts, otherwise, just all I can get out of the 292. Maybe I should use the Edelbrock on my 272 and get something else when I get the 292 further along?
Campsite
Visits: 632
Two Add my two cents on this subject. On my 312 I was looking thru the Holley Book. And found the number for the replacement Carb. It was for a 289 HIGH PERFORANCE, Not much of Difference between the two. I have had it on the 312 for three years now, works great. My 312 is built to Run hard,
I can supply the number if needed. Bob
Bob
Posts: 1.9K,
Visits: 195.0K
Carbs are always a source of varying opinions. I have to go with Frank on the tuning part. I've run 1405 Edelbrocks on stock 292's, supercharged 320cid strokers, 265 and 350 scrubs, they all just worked. The tuning manual looks a bit confusing, but once you find the right page and graph, it's pretty simple. Change the rods, pull the top and do the jets, no fuel all over. All the secondary's have stayed stock, even with the blow thru supercharger. Only had to change the rod springs on the blow thru setup. I especially like the low rpm-part throttle performance. I'm told the new Holley's are better there than they used to be. Edelbrocks will work with minor mods no matter what you do to the motor, short of all out racing. And maybe there, too.
I've also had a couple Holley's that drove well, and a couple Q -Jets. The Q's I had done by pro's, I have no clue how they work, and my attempts to tune them proved it.
The only problem I've had, both Holley and Edelbrock, is getting the electric choke to work right in the summer. On a good, cold day, fine. But I never seem to be able to reset them right for summer. The manual choke solves that.
The 525 Street Demon JR is technically a Demon carburetor but they are not around as their own company anymore; Holley owns the brand now. That is a good carb, too. What I understand about the Summit carb is that it uses Holley parts, so tuning should be a breeze and parts to do so should be easy to get. I don't really understand the building up and building down thing. The made in China part would bother me, if it is true. I've gotten to a point where I try not to buy made In China if at all possible, even if it is a quality product. I think any one of them will do the job just fine. When I switch from My Edelbrock 600 to the Holley 570, it was a night and day difference from idle to 6000rpm and it got better mileage. That was with only a couple hours of tuning after the initial installation vs many, many hours of trying different things with the Edelbrock, before I learned about the air valve "fix." This isn't a Holley is better than Edelbrock statement. I think what really is happening is that the Street Avenger series is a modern carb whereas the Edelbrock is not and the new tech in the SA allows it to work better. With any of these, you should expect to tune it. They will all probably advertise some version of "guaranteed to work out-of-the-box" and they probably will but working out-of-the-box and properly tuned can be two different things. It could turn out that out-of-the-box is perfect, but probably not. Do your best to pick something that is inline with the goal of the engine. Don't go too big, and don't take a smaller one that you will need to replace with a bigger one in the not too distant future. With every one of these carbs, you should be able to email the manufacturer to find out what they recommend for your application. They know their carbs better than anyone else and can tell you if it will be a good fit or not.
Outlaw56
Visits: 26.9K
My reference to building up or down was with regards to the carberator out of the box and changing it with a kit to make it perform better for a higher or lower performance engine. I got the impression the Summit 4100 Replica might be best suited out of the box for a souped up 272 or 292 and not so great for a stock 272. When the thread poster tried it on his stock 272, he thought it was too rich. He contacted Summit to get the parts to tune it down, he was told the only kits available were to tune it upwards for higher performance engines. Hope that makes sense. Of course the made in China was just repeating what I read on another forum but has never been confirmed.
With no experience in these carbs, I can say I am impressed with the Edelbrock Performance 500 I have for my 292. Problem is I dont have nothing to compare it to.
steinauge
Visits: 1.4K
I am using an Edelbrock 600 on my mildly modified 292 with zero issues, just bolted it on,set the pilot screws and idle speed.I have used the Summit carb both 600 and 750 CFM versions on a couple of other engines with really excellent results. I would buy either again,but would probably lean toward the Edelbrock just because I had such good results with Carter AFBs for so long.
Outlaw56
Visits: 26.9K
From what I have read (no actual experience), its pretty easy to over carburate a stock 272. The Edelbrock 500 Performer Series is leaning in the direction of "overkill", but it will work. If the stock engines future includes a more aggressive camshaft, bigger pistons, increased air flow with ram horns and increasing exhaust pipe and muffler diameter, I would hope the 272 would grow into the 500. Edelbrock also makes the 500 in the Thunder Series which I believe is the same as the Performer but includes adjustable secondaries. The Edelbrock 500 Thunder Series is the one I have brand new in the box which I had purchased several years ago for my 292. That 292 is going to get rebuilt one day and I am wondering if I should get a 600 for it and use the 500 in the 272. Any thoughts? Neither of these Y blocks is going to be for hot rodding, just daily drivers. I'm hoping to get good running engines with good gas mileage. Maybe the 500 series will be good for both?
Outlaw56 (11/4/2014)
........ Any thoughts? Neither of these Y blocks is going to be for hot rodding, just daily drivers. I'm hoping to get good running engines with good gas mileage. Maybe the 500 series will be good for both? It’s difficult to go wrong with a vacuum secondary carb. The secondaries on those are good at only opening the amount required by the engine. Whereas a mechanical secondary carburetor is very rarely at the optimum sizing for an engine (either too big or too small), being oversized on a vacuum secondary carb will always insure the engine will get the amount of air it wants. I run a 525cfm Road Demon Jr. on my own 272 now and it runs fine. I’ve also run a 780 Holley on the same engine but drivability at low rpms was not as good as it seemed to be more sluggish right off of idle. Full throttle performance was fine though with the vacuum secondaries. I borrowed a friend’s 600 cfm Edelbrock carb and it had a noticeable flat spot or hesitation right off of idle compared to the 500 cfm Carter that I use to run on the same engine.
