'55 F100 rear Cab Mounts
http://forums.y-blocksforever.com/Topic98084.aspx
By Red_John - 13 Years Ago
I recently put my cab back on the chassis but the rear cab mounts were difficult to engage. Does anyone have experience or a link to instructions to help me know if I did it correctly?
John
By lyonroad - 13 Years Ago
John, I put my floor jack under the cab rear flange near the centre. I jacked it up a bit and wiggled the cab around until I could get the bolts in. You could also loosen the brackets on the frame until you get the mounts in place. However, if memory serves, the arms make it difficult to get a wrench on the upper bolts once the arm is in place. I had some cab alignment issues so I purchased a set of adjustable rear cab supports from Champion Auto Parts in Orange County Ca. They worked very well, however I can no longer find that company on the internet.
Thanks Mark. I think I can get the adjustable parts from Mid50s
You are right John. I see they have two styles. The ones I used are the $200.00 one which are now $50 bucks more than what I paid. Such is inflation.
