paxton s/c brackets
http://forums.y-blocksforever.com/Topic88863.aspx
By 5d6fairlane - 13 Years Ago
I need brackets to mount a Paxton sn2000. Anybody got pictures or templates or know who makes them.
Thanks Joe
By Rono - 13 Years Ago
Joe;
If you are trying to set-up a SN2000 to a Y-block, I don't believe that the Y-Block brackets will fit the head unit of the SN2000. I would email John Erb at; johnerb@sbcglobal.net to find out for sure.
Rono
By ecode ragtop - 13 Years Ago
Joe, A sn2000 should be the same bolt pattern as a vs57 so any of the McCulloch brackets should fit the supercharger head , I have a few brackets and will try one to be sure. What are you trying to put it on? Tom
I posted this question before I picked up the blower only to find out when I went to get it that it is a reverse rotation novi 2000. I still purchased it as it came with 9 top pulleys and three lower so now I will be going back to the vortech v2 and selling the novi less pulleys. The shaft size is different between the two but I can get a different hub made. I was going to mount it on the passenger side but if I put it on the driver side I can mount a a/c compressor later. I have someone that is going to machine my lower v belt pulleys with a flange on the front to bolt the blower pulley to which was going to be attached to a innovators west dampner but am now considering just a crank hub.
By pegleg - 13 Years Ago
Check with Craig Connley at Paradise Wheels in Ca. He has many of those brackets
