yblocks on assembly line
http://forums.y-blocksforever.com/Topic83113.aspx
By snowcone - 12 Years Ago
I found these images of y blocks being assembled on the Australian Ford production line.
By Doug T - 12 Years Ago
There are some interesting variations in those engines, some truck oil pans some pass car pans, some exhaust dumps on left others on right. Note the fixture for suspending the engine, it makes use of the RH motor mount tapped holes and the 7/16" tapped holes just above the oil pan rail. The engine can be turned over for access to the crank and it still makes the front and back accessible using this fixture.
Doug
This photo shows that they were building cars and trucks at the same time, as well as the "pommy" models
