Wheel bolt pattern
http://forums.y-blocksforever.com/Topic72261.aspx
By Daves56fairlane - 14 Years Ago
I want to order some aftermarket wheels for my '56 Fairlane club coupe. Can someone tell me what info I need to know to order them. Bolt pattern etc., my spindles and hubs are stock '56. Thanks,Dave
By glrbird - 14 Years Ago
4.5 in. bolt circle, for wheel studs, and make sure you dont get too wide or things will rub the tires, A- frames , wheel wells etc.
By Rono - 14 Years Ago
Dave;
If you have a spare you can measure the backset. That will be the distance from where the wheel mounts on the brake drum to the outside of the rim.  You will need to try to find wheels with similar dimentions because there isn't much wiggle room for wider wheels and tires. You will hit the fender well on one side and the leaf spring U Bolt on the other.
Rono
Thanks Gary and Ron. That's what I needed to know. I want to order chrome smoothie wheels for my '56. I'll send pictures when I get them on Dave
