Wanted alum. Timing Cover
http://forums.y-blocksforever.com/Topic58532.aspx
By hjh - 14 Years Ago
Wanted aluminum timing cover for y- block   Call Harry 513-868-3311 If no answer leave message & will return your call
By 57FordPU - 14 Years Ago
Hi Harry,
It seems no one has come up with an aluminum timing cover yet, perhaps this new post will shake the trees a little.
Would it be legal for you to run a marine aluminum timing cover?  Tim McMaster runs one on the FED.  He fabed up an electric water pump on it and it works pretty good.  It usually requires a marine aluminum pan as well because the cover is much shallower that stock.  However, I believe a stock pan could be modified to work.  Perhaps Tim will chime in.
Just trying to help.
Charlie
Charlie
Thanks for the tip.I should have one around here,if I have any luck with it I will post the info.It`s going to be some time before I tackle the project.
 Harry
