OIL PASSAGE QUESTIONS 64 292
http://forums.y-blocksforever.com/Topic51933.aspx
By lrs30 - 16 Years Ago
When I did my compression test, and valve adjustment, I fired it up with the valve covers off, and notice oil only climbing up the push rods, I see that there are 2 small tubes the are bent to aim towards the rocker shaft, should oil come out of those aswell? The seem to be loose fitting and not really pressed into the head. The heads where fairly clean of build up, I did notice a fair amount of build up in the small hole on each rocker.. So I guess my question is should oil come out of the tubes? Would it be in my best intrest to remove and soak the rocker assembly in my parts cleaner and blow out all the holes?  Any and all advice will be taken with great thanks.. Ryan
You should see oil flowing from the tubes. The best thing to do will be to pull the rocker assemblies, take them apart and clean them. When they're off, make sure oil is getting to the passage in the head.
Is there a diagram around that shows the oil passages or a Y block?
By Barry L - 16 Years Ago
 Here's a few pics of the passage in the head... the dog leg on the chamber side and the hole under the rocker stand. Oil should flow from the center cam bearing up thru the block (one passage on each side), across the dog leg,up thru the head,thru the rocker stand into the rocker shaft,oiling the rockers ; the excess flows out those tubes to return to the oil pan.    Barry
By mctim64 - 16 Years Ago
Is this what you are looking for?
http://forums.y-blocksforever.com/uploads/images/5f5522f5-250e-47be-908f-9e65.jpg
MAN I LOVE THIS SITE!, You guys ROCK, I am tearing it down to clean and check this out ASAP!
By oldcarmark - 16 Years Ago
At the very least you will need to diassemble and clean out the hollow shafts.Several topics on this if you do a search using "search" at top of page.By the way the oil you are seing on the pushrods originates from an oil squirt holet in the front of the rocker arm.There is also one on the back and these small holes are almost always plugged up too.
By Fordy Guy - 16 Years Ago
Also important to mention about the tubes at the end of the rocker shafts is that the oil that comes from these goes down thru the hole in the head and the front one helps to oil the timing chain and the other to oil the distributor gear. There are mixed opinions about closing these tubes off so as to pressurize the rocker shafts for better oiling of the rocker arms. Some members say to insert a small drill bit in the end of the tube and squeeze the tube around the bit to reduce the flow out of the tube and still have an adequate amount of oil to oil the dist gear and timing chain and a higher amount of oil supplied inside the rocker shafts for oiling the rocker arms.
Once you have the rocker stands removed, spin the engine over to make sure you have an adequate supply of oil coming from the hole from the center main bearing that will feed the rocker shaft.     Hope this helps
By Y block Billy - 16 Years Ago
The early ones flowed down the holes in the ends of the heads, they later changed and the tubes were directed down a pushrod hole. I think the holes in the ends couldn't keep up with the flow and what seeps down those holes after the change was adequate enough for lubricating the dist gear and chain.
my full pressure 292 can idle with the covers off and all the leakage goes down the lower drain holes in the heads, also with full lube oil runs down the push rods. with good lifters and cam the pushrods .rotate well. . when i did the engine made sure to use tried umbrella seals for a ford 289. engine never smokes and oil consumption good. . engine in 1949 mercury. i/2 ton
rocker shaft cleaning ,must remove core plugs to properly clean sludge. to many on this site worey about oil return,the tubed that bleed off pressure exit into the outer drain holes Exhaust manifold side. these holes easly cleaned with oil hole brush. so when you throw away the bleed tubes and go to pressure lube the oil flow goes threw to the same aria the tubes direct, just be sure to block the holes the tubes wherein.
Meteor, properly installed overflow tubes empty into the rear pushrod hole, not the drain holes for the rocker area.  Pressurizing the rocker shafts increase the amount of oil that must exit the lower oil drain holes.
if you have a head off look at the drain holes close to exhaust side, the oil from drain tubes (via the pushrod hole comes out the same spot. if the lower drain hole is clean same amount of oil goes to oil p drive and timing chain hole .the holes at front of block 1 is lower than the other so some of the drained oil will go to the rear oil pump drive gear
in fact with drain tubes are removed and oil hole blocked less oil spills than when tubes in. this site had a good storey on proper blocking the tubes. run a 5/16 tap down the rocker stand drain hole ,take a 5/16 allen screw and grind a point on lower threaded part. this blocks the oil and positions the stand making it easeyer to install. ps the hole for the drain tube is rich size for 5/16 tap.
unless 1 removes rocker shaft core plugs ,not likly you will clean the sludge out of the shaft as it accumulates preset drain tubes
