By carl - 15 Years Ago
I have a 56 ford mainline wagon for sale.It has a 292 engine,stick shift.Car is complete but needs total restoration.Price is $1500.00,located in central Ohio.If it dont sell in a couple weeks i will part it out. Carl Lynn Ohio E Mail is CL56VIC@YAHOO.COM
By shakey pete - 15 Years Ago
Carl i,m still looking for clutch pedal assem for my 54 are you going to part out the wagon Shakey Pete
Pete: I have a '54 stick shift changeover less transmission, but I prefer not to break it up. Even have the shift rods from the column to to transmission, no column. But, if the pedal assembly is worth enough to you, I'll sell you the kit.
John I,m very interested in your clutch pedal assem for a 54 ford with a yblk I need the pedal linkage the trans bellcrank and push rod for the release bearing, let me know your price I,ll pay through pay pal many thanks Pete
Pete I sent you am pm some time ago and said that i have what you need if the parts from a 55 ford are the same as what you need Carl Lynn
Sorry Carl never recieved your message before I really don,t know if a 55 ford would work but you would think a 54=55=56 would all be the same shakey Pete
Pete: I did not know that Carl was trying to deal with you, I will back off until you and Carl work things out. I believe the '55-'56 equalizer from the frame to the engine is shaped differently to clear the left exhaust pipe on dual exhaust cars. '54s didn't have factory duals.
Hi John whats your price I have clutch trans and everything except!!!! the (clutch pedal assem down to the trans this includes the push rod ,bellcrank and the pushrod for the release bearing and return spring shakey Pete
By junkyardjeff - 15 Years Ago
If Carl cant find you a 54 cluch pedal let me know as I might know where some are.
Pete: I checked my stuff to make sure everything is there. It isn't. I have two clutch pedals and arms(??), a brake pedal, the clutch linkage except for the spring from the throwout arm to the frame, and the bracket that bolts to the engine and supports the inner end of the equalizer. I do have the heavy under dash spring and the adjusting J bolt, and the torsion spring that returns the brake pedal to the top. The '55 stuff Carl has will also fit, and again, I won't horn in on Carl's deal, he was here first. I seem to remember something being different between the stick and auto brake pedals, beside the wider pedal pad. Something about the pedal pivots.
John I cant get any response out of Pete so i guess that he has already found what he needs elsewhere.I checked The parts numbers on the 55 56 parts and some have B4 (54) numbers so it looks like 54 55 56 are the same on these stick shift parts Carl
By MoonShadow - 15 Years Ago
It's a long time ago but when I converted my first convertable, about 1960, I bought a pedal setup from a local guy. I'm sure he said it came out of a 54. Fit perfectly! So if my memory's anywhere near correct (this time?) the parts interchange. Chuck in NH
Hey John and Carl I want to thank you for trying to round up the parts for me you people do good things for this y-blk site had lots of emails out, finally 1 came through so many thanks for your effort and time!!! shakey Pete
