By Gary - 15 Years Ago
I'm in need of a y-block steady rest (front motor mount) for a 1955 Ford sedan. Located in Birmingham, AL gadams2@bellsouth.net Thanks
By Jim Rowe - 15 Years Ago
I have a 1956 Ford Sedan, and I don't use the steady rest. It is overkill. It will work fine without it, unless your looking to be a 100 point car. Then you will need the lower dust shields that go in front of the engine below the rad hose and generator.
Jim
By oldcarmark - 15 Years Ago
As Jim said most take it off and leave it off.You will need to remove the damper to install it.There is likely one on Ebay if you search Y-block for instance.
