Need one set of used ECG 6554 1.54 ratio rockers...
http://forums.y-blocksforever.com/Topic40421.aspx
By Daniel Jessup - 15 Years Ago
Anybody have a used set of ECG rockers (only want one side)? Would prefer a decent shaft, wear on rocker pads not too much of an issue, just so long as the play in the rocker pivot is not too terrible. This is going on a used motor that already has a set on one head.
My address is 2581 Northwestern Pike, Winchester, VA 22603. Let me know cost and shipping per USPS priority. (may fit in a flat rate box?)
Dan Jessup
danaxjessup@yahoo.com
By mctim64 - 15 Years Ago
Is this for your test stand engine?  We have one for you, I think Charlie will contact you. Wink
Tim, I will give Charlie a shout. Those teapot cores have been pretty good and are cleaning up well. Hopefully I can get a good read on the modification of the fuel bowl (and pressurization of the carb) for the blower bonnet. I have one bank of ECG's on my test stand motor, and need to have another set to match the other side. I do not plan to pull the heads, but do plan to put a different cam, new lifters, and maybe even new valve springs before I put everything else on it to let it rip. Wink Wait a sec, did I say "rip"? w00t
What am I worried about? This is a Y block...Cool
Jessup
