Oil pump question
http://forums.y-blocksforever.com/Topic18161.aspx
By ford1940deluxe - 17 Years Ago
These oil pumps belong to 292 Y-block
What is the difference between these oil pumps?
Which one is the best?
Jorge Nuviola from Argentina
By mctim64 - 17 Years Ago
The one on the left is a "spur-gear" type the one on the right is a "gear-rotor" type, wich is thought to be the better of the two.
By Ted - 17 Years Ago
Doing a search using “gerotor, gerorotor, or spur gear oil pump” gives some past threads on the subject.  Here’s a couple of links to past threads.
http://forums.y-blocksforever.com/Topic12065.aspx
http://forums.y-blocksforever.com/Topic8082.aspx
Ted (11/4/2008)
Ted, I read the old thread on the gerotor oil-pump. Have you found any companies that are prducing these pumps yet? I have seen the kits, but no complete pumps as of yet.
mctim64 (11/4/2008)
Tim.  No companies that I’m aware of is reproducing the gerotor style of oil pump for the Y.  I believe the last company to make a replacement gerorotor pump for the Y was Dynagear.  I’m currently using the Melling gerotor kits to rebuild existing pumps as suitable cores become available.
By mr4speedford - 17 Years Ago
I have melling oil pump rebuild kit for the stock 1960 pump that I have, Is there any rebuilding tips I should be aware of? I planned to throughly clean it, possibly emory or crocus the bore. Do you pack it with vaseline or just fill with oil (fresh motor)? Thanks for any guidance.
But back to design differences. The gerotor pump has four lobes on the drive which takes roughly 180° of crankshaft rotation to fill the pumping chamber. The spur-gear pump for the Y has a 14 tooth configuration which effectively has only 51 degrees to accomplish the same thing. Because the gerotor pump has roughly 3½ times the work time to fill its chamber, the oil is allowed to ramp much more smoothly into the pump chamber and likewise shut off much more slowly as the cycle is completed.
ok conlusion: the first bomb in the photo is a Y-bomb or gerorotor stock bomb, these needs 180° of cranckshaft and de second bomb in the photo (aluminium) needs 51° degrees of cranshaft
is correct?
ford1940deluxe (11/5/2008)
is correct?
I think you have it backwards, the Aluminum one is the "Gertor" pump (bomb) and the rusty Iron one is the "Spur-gear" pump. The aluminum one is favored.
mr4speedford (11/5/2008)
I have a melling oil pump rebuild kit for the stock 1960 pump that I have, Is there any rebuilding tips I should be aware of? I planned to throughly clean it, possibly emory or crocus the bore. Do you pack it with vaseline or just fill with oil (fresh motor)? Thanks for any guidance.
For oil pump priming, I only recommend using engine oil.  Rotor end play should be 0.002"-0.003", inner rotor to outer rotor clearance should be 0.005"-0.010", rotor to housing clearance should be 0.006"-0.012" and torque specs for the cover itself is 95-100 inch pounds.  Be sure the oil pressure relief valve works freely in its bore.
Thanks Tim for clarifying which pump is which.  Another identifier for gerorotor oil pumps is that they will have flat covers.  Once the covers are removed, the differences become obvious.
Thanks boys!!!!!!
Thanks again Ted.
