Oil pan drain plug leak
http://forums.y-blocksforever.com/Topic170124.aspx
By geo56 - 6 Months Ago
My 56 Victoria with a 292 has the large size drain plug on the oil pan, I think 1 1/16 or 1 1/8. I have been putting up with the quarter size marks on my driveway and have wondered if modern oils now go where the old oils didn't. I have tried replacing the copper washer with a neopreme one and when that still leaked,  I tried a red silicon sealer smeared on the neopreme washer. It still leaks . Can anyone tell me if they have found a good fix for this?
By 55blacktie - 6 Months Ago
You might try Permatex Aviation Form-a-Gasket on the threads.
By slumlord444 - 6 Months Ago
Replace the washer on the drain plug
By KULTULZ - 6 Months Ago
If the pan and plug are original to the OEM engine, the thread size should be 7/8" and the correct washer (crush) should be copper. The drain plug threads (and possibly pan threads nay be stretched.
Try a new washer first and if they doesn't stop it find a new drain plug and maybe chase the pan threads,
http://forums.y-blocksforever.com/uploads/images/532e82a4-8910-4e3f-9fe6-8062.png
http://forums.y-blocksforever.com/uploads/images/4e2edd3f-06b4-4299-b230-98bd.png
http://forums.y-blocksforever.com/uploads/images/826369af-a153-49b1-90a2-1d5f.png
  • If you have to glue something... https://www.ford-trucks.com/forums/images/smilies2/sad2.gif
