Intake manifold retaining cup washers
http://forums.y-blocksforever.com/Topic169355.aspx
By cokefirst - Last Year
I am hoping Ted can respond to this.  I was cleaning up some parts and noticed that there are three distinctively different cup washers that retain the intake manifold to the heads.  I notice that one is totally dome shaped while another seems to be of less material, and has a flatter area where the stud goes through the part.  The  third variation is about halfway between the two.  There may be more.  Are any of these significant?  Is there a certain year when they were changed?  Thanks
By Ted - Last Year
The intake manifold clamps (aka turtles) went through several variations during the years of production for the Ford Y.  I find no fewer than six different styles not including what was made by the aftermarket.  For the 1963 and 1964 Ford pickups and trucks, they were cast iron.  For the years prior to this for both the cars and trucks, they were stamped steel and depending upon the year, the styles or overall appearance changed.  Here’s the link to an older thread discussing some of those variations.
http://forums.y-blocksforever.com/FindPost150181.aspx
By 55blacktie - Last Year
Interesting. Although there are many different styles, are they all application-specific as far as fitment is concerned? Which is correct for the ECZ-B intake? Can the stamped steel "turtles" be used with the Mummert aluminum intake? If not, does John include aluminum turtles with the manifold?
By Ted - Last Year
The Mummert 4V aluminum manifolds do not require the intake clamps (turtles) as there are no notches or cutouts in the manifold where those turtles would normally hold the manifold in place.  By design, the Mummert 4V manifold uses bolts to hold the manifold in place rather than the original studs and hardware.  On my end, I machine the Mummert manifolds so that there are four slots or notches which allows the use of the original intake manifold studs.  Using those manifold studs helps to keep the intake manifold gasket properly aligned during the intake installation process.  Because I use the studs with the Mummert manifolds, I end up using the factory turtles to help take up some of the extra length afforded by the studs.  Here are some pictures that give a better understanding of this.
http://forums.y-blocksforever.com/uploads/images/b662e143-514e-4322-84a1-271b.jpg
http://forums.y-blocksforever.com/uploads/images/0eb1537b-b2bb-407d-8fed-5491.jpg
http://forums.y-blocksforever.com/uploads/images/7c42747c-487a-4b41-a415-a550.jpg
Unless you’re worried about being concurs correct for the intake clamp style being used, then if it fits, use it regardless of style.  For the 1957 cars equipped with the ECZ-B intake manifold, the supplied intake clamps (turtles) were stamped steel with a slight flat on their tops.  Here’s a picture of those intake turtles that helped to hold the ECZ-B 4V intake manifolds in place.
http://forums.y-blocksforever.com/uploads/images/bf327fc7-62e5-466e-a8f8-bd3c.jpg
http://forums.y-blocksforever.com/uploads/images/faeca7ce-7a8f-4aff-a61a-ba26.jpg
White grease, alone, not enough to hold the intake gaskets in place during installation of the manifold?
By Ted - Last Year
55blacktie (10/29/2025)
I would not trust the grease to hold the gasket in place if not using the factory studs.
Thanks Ted, I have owned Y-blocks for over 55 years.  I just never noticed.  I was cleaning these up using the Daniel Jessup method.  That works great.  I am cataloging the OE hardware and sorting it via Ford part numbers.  I just happened to have about 10 of them that I cleaned and polished.  I guess you are never to old to learn!  Thank you sir.
I did some more research on this an now I am puzzled.  I checked both my 1955-57 Chassis parts book and the 1949-1959 Ford car parts book.  Two part numbers are listed.  B5A 9446-A, says it is 1.83" long and that is the one with the flattened top.  The fitment shows 1955-56 S (Thunderbird), the 1955 A (passenger car) with the 182 HP engine, 56 Fairlane, Station Wagon and passenger car with special engine.  (4bbl?) and the 1959 Passenger with the 292 engine.
Part number EAD 9446-A is 2.21" long and this has the domed shape.  That part number shows that it fits the 54-55 passenger with 239 or 272 engine, the 1956 passenger car, except Fairlane & Station Wagon with 272 engine, All 8 cylinder passenger and Thunderbird engines, and the 1958 models with 292.
The reason I am puzzled is that both my 312 engines in my 57 Skyliner and my 57 country sedan have the shorter clamps when the book says it should have the longer ones.  I pulled one and tried putting on the longer (2.21") and it will only fit if it is put in at an angle, there is not enough lip to have the clamp fit straight across.  Is the book wrong, or should my engine have the longer ones installed at an angle?
By Ted - Last Year
My experience finds that the ECZ-B four barrel intake manifolds used the shorter (flat top) clamps. It’s not unusual for a part that’s listed in the catalog to be superseded later in the year by a part that’s different than was listed in the catalog at the beginning of a model year.
