By geo56 - 4 Months Ago
I have a 56 Victoria with a 292 and dual exhaust. I have been putting up with a rattling noise from underneath and noticed that my exhaust pipe on the right side hangs down a little lower than the one on the other side because of the heat riser valve being on the right side. Because of this, the exhaust pipe is below center in the hole in the frame that it passes through causing it to rub and rattle. I think eliminating the valve would give me good clearance. I live in Tulsa and wonder if the winters are severe enough for me to really need the valve. Do cars really run much better with them. I'm sure they cause a condensation problem on one side and these Fords were notoriously bad on exhaust systems. I am leaning on deleting the valve . Also, should I decide to keep the valve, does anyone know for sure which side it should be on. The only illustration I could find showed single exhaust with the crossover pipe. George
By DANIEL TINDER - 4 Months Ago
If the Vic dual exhaust is same as T-Bird, Rt. side is correct. Tulsa isn’t the arctic, so valve likely not needed. Get a new gasket before reassembly though.
By oldcarmark - 4 Months Ago
You can remove the Heat Riser and replace with a Spacer available from the usual Sources. You don't need it for summer driving. Same as the Choke. You can back off the Choke adjustment so there is minimal Spring Tension on the Choke Plate.
By KULTULZ - 4 Months Ago
"I have a 56 Victoria with a 292 and dual exhaust. I have been putting up with a rattling noise from underneath and noticed that my exhaust pipe on the right side hangs down a little lower than the one on the other side because of the heat riser valve being on the right side. Because of this, the exhaust pipe is below center in the hole in the frame that it passes through causing it to rub and rattle."
The valve should be on the LS of the car if factory dual exhaust assembly.
Did the car come from the factory with dual exhaust, or was it converted from single at some point? If not the original inlet pipe (muffler shop replacement), it may not be correct in drop length. Are the exhaust manifolds (esp LS) correct (may be later year if a dual upgrade).
Looks like from your picture that I have been running mine on the wrong side. Mine is currently on the passenger side which might explain the low hanging exhaust pipe. I wonder what I have hurt by running it this way. My car had the thunderbird V/8 option and still has the original manifolds. Exhaust and tail pipes are stainless and were ordered from Concours years ago.
OK, hold on a minute ...
I re-checked cataloging and there are two ILL's for DUAL EXHAUST. One ILL reads 1955/56 FORD DUAL 'TYPICAL' and is the one I posted showing valve install on the LS. A few pages down, another ILL is shown titled 1956 FAIRLANE 'DUAL EXHAUST' and shows the valve on the RS.
So that is my mistake. Your install appears correct.
I wonder if it makes any difference which side. I am still leaning towards removing the one that is currently on the right side, thus raising my exhaust pipe fpr more clearance. It would allow both sides to blow out condensation on cold mornings. Glad I ordered stainless pipes when they were affordable. I am on my second set of mufflers. These cars are hard on exhaust systems. Just an after thought: The fairlane models had the teapot 4 barrel with the hot air choke using the heat tube in the intake manifold.Could be that this specific set up required the valve be on the right side.
By miker - 4 Months Ago
There’s a time and place for the heat risers, but I haven’t had one on any old vehicle in years. They all got headers. So just put yours back as needed to stop the rattle. Any engine will have a muffler rust problem if they aren’t driven far enough to warm the whole system. Takes heat to cook the moisture out, and even in stainless system you can plug up the packing if it’s that design.
By paul2748 - 4 Months Ago
I replaced mine with a spacer, but if you are having problems with the pipe hitting you can get rid of it. You will have to thread the stud down further or add spacers between the pipe and the nuts to make up the un-threaded space. The studs usually are not threaded all the way down when the valve was used.
By 55blacktie - 4 Months Ago
The 55-57 Tbirds have the heat-rider valve on the right/passenger side; the choke is on the same side, whether it's for a Teapot carburetor or 57 4150. Even if you have a full-size, it doesn't make sense to me to have the heat-riser valve on the opposite side of the choke. I have a modern carburetor/w electric choke & Sanderson headers. The ECZ-B intake manifold heat crossover is blocked as well.
Does the crossover heat tube need to be blocked off if it is not rotted? Mine was a stainless replacement that I pounded in years ago.
"Does the crossover heat tube need to be blocked off if it is not rotted? Mine was a stainless replacement that I pounded in years ago."
No. As long as the tube itself is intact, there will be no exhaust leak (if the manifold crossover tube openings have not been wallowed).
Now here is the problem. If one defeats the heat riser valve, there will be very little hot air (exhaust crossover) under the intake manifold carb plenum to atomize the fuel charge properly and also the hot air choke draws the heated air from that source (via the crossover tube). The choke may not release fully or be slow in doing so. The heat riser does more than just provide hot air to the choke. All of this also depends on where you live and what weather conditions you experience. While the ambient temp may not get very low, the humidity may be high and possibly lead to icing.
FORD installed this system(s) on most cars so it would be drive-able under most any condition.
Choke settings were usually adjusted for winter and summer operation. The heat riser valve itself was also lubricated with a special lubricant to keep it from hanging.
What gets me is the RS inlet pipe hanging low. Did the vendor offer a choice of pipes, one with the valve and one with the valve removed?
As for condensation in the exhaust system, that is natural, (especially in high humidity areas) if not driven long enough to heat expel it (all short trips - little heat).
Do the service replacement mufflers have weep holes drilled?
Does yours have bumper exhaust outlets?
As for the heat riser valve itself, there would be no difference if mounted on either side (duals).
The way cataloging reads - FYB
1955 FORD - ? 1956 FORD - RS 1955 BIRD - LS 1956/57 BIRD - RS
Everyone run out to the garage and report ...
geo56 (8/18/2025)
Does the crossover heat tube need to be blocked off if it is not rotted? Mine was a stainless replacement that I pounded in years ago. As was mentioned, living in a cold-climate region is a consideration; however, the Mummert aluminum intake manifold has no heat crossover. If you don't live in a cold-climate region, or do not drive your car at/below near-freezing temperatures, I don't think you'll have reason to be concerned. On cold, not freezing days, it might take a bit longer for the engine to reach normal operating temperatures. Regardless of the crossover or type of choke you might have, running the engine for short periods of time without it reaching normal operating temperature is not a good thing, no matter the make, model, or age of vehicle (unless it's an EV).
Well, I think it has more to do with how the car will be driven/used either as a driver or something pumped up.
If you have a street driver or restoration, I would imagine one would retain the feature, especially if the wife or daughter drive it. If street performance, the fuel curve will most likely be rich enough so it won't be as noticeable.
I think MUMMERT went this direction as the intake is meant for performance (raised carb pad/runners).
Now the BLUE THUNDER kept the feature I believe but have never seen one, A photo shows one end of the cross-over as being blocked and the other appearing open but than again I see a provision for the crossover tube.
By Ted - 4 Months Ago
The heat riser valve at the exhaust and the crossover tube within the intake manifold really do have two different functions. Those cars that had a manual choke still required the heat riser valve but for a completely different reason other than being required for an automatic choke operation. By design, the heat riser valve located at the end of an exhaust manifold is designed specifically to force exhaust flow through a special passage within the intake manifold which in turn heated the carburetor. This was to prevent icing at the carburetor which happens at the dew point temperature and is not necessarily anywhere near the freezing point. Depending upon the humidity, the dewpoint temperature that creates most of the carburetor problems would be in the 40's- and 50's-degrees Fahrenheit. Icing was a major issue as it did not only create fuel mixture issues, but it could also keep the throttle from completely closing which posed a serious driving hazard. The heat riser valves were used on vehicles of all makes well into the Seventies although the automatic chokes had long switched to other means in which to operate. There was a point in the late Sixties where the exhaust heat riser valves were being discontinued in favor of heated air going thru a flexible tube going directly to the carburetor thus eliminating the need to direct the exhaust directly thru the intake manifold at startup. With those setups, there were air operated flapper valves located at the air cleaner to control the amount of heated air coming from the exhaust to the carburetor. The air tube within the intake manifold is specific to the automatic choke operation. For the Fords, 1958 was the last year the intake manifold air tube was used for this as the heat source for the choke switched to the right-side exhaust manifold in 1959. For the FE with three deuces and the dual quad setups, the heat source for the automatic choke came from the left side exhaust manifold.
Thanks Ted. Does it make any difference which side it is on for the Fairlane models with factory dual exhausts?
geo56 (8/21/2025) Thanks Ted. Does it make any difference which side it is on for the Fairlane models with factory dual exhausts? That would be a ‘No’ on being side specific for the dual exhaust equipped vehicles. To the best of my knowledge, the U.S. 1954-1957 Fords and Mercury’s with dual exhausts had the heat riser valve on the right side (passenger side) of the engine. Reasoning for this is likely due to how busy the engine compartment is on the left side due to column shift, steering box, clutch linkage, etc. As a side note, it’s important that the bimetal spring that operates the valve movement is installed correctly. If installed incorrectly, the valve will be open when cold and then start closing as the engine heats up. Just the opposite of what it's supposed to do.
