Emergency Brake cable
http://forums.y-blocksforever.com/Topic165657.aspx
The emergency brake cable at the end of the handle of our 1956 Ford is fraying and not letting the cable fully release. Is there anything I should be aware of after lowering the handle mechanism to get the cable ball to disconnect or come out. It appears I should remove the threaded adjuster rod nuts first under the car.
Any suggestions are welcome. At 79 it’s getting tougher to do the tasks I didn’t think I would ever need to do.
By carl - 2 Years Ago
I probably have a new cable if you find out you need one   carl
Thanks…Already ordered. The convertible is 6” longer. X subframe must make a difference..
