292 rod bolts
http://forums.y-blocksforever.com/Topic164983.aspx
By Ronfox69 - 2 Years Ago
Have a 1955 mercury 292 that I need a set of rod bolts for. The rod is EBU. Have a new set of arp 9005 bolts but they won't work. The heads of the bolts will have to be ground which arp told me. Arp said they haven't made that bolt for 2 years. The problem is the threads on the new bolt are about 1/4 inch too short. Arp told me that I couldn't use a die to thread the bolts longer
Said their threads are rolled. I am going to try to post a picture of the old and new bolts side by side. Thanks for reading. Ron Fox
By Cliff - 2 Years Ago
I use for a 292 rod, Ford 390 bolts and for a 312 Ford, 400 SBC bolts
Thanks I will look into that
By Ted - 2 Years Ago
Ron.  I looked at the 154-6005 bolts I have here and length wise, the threads are long enough for the EBU rods.  As a general rule, I use 0.006” as the value for the total amount of material removed from the rod and cap interface when resizing the rod big ends.  Most of the time I get by with a total of 0.002”-0.003” cut from the rod and cap interface for resizing purposes.  If your rods have been heavily milled or cut in preparation for resizing, then there’s a chance that the ARP bolt threads will be too short.
I looked at the alternative ARP rod bolts (150-6005) I have used for the EBU rods and they are the same overall and thread length as the 154-6005 bolt set.  Here are a couple of pictures of the alternative bolt set from ARP.  Both the 154-6005 and 150-6005 bolt sets are too long for the ECZ, C1TE, and C2AE connecting rods.
http://forums.y-blocksforever.com/uploads/images/390463df-14ca-4a54-974b-fa7d.jpg
http://forums.y-blocksforever.com/uploads/images/bda31db8-4f9b-4fb2-9579-3b3f.jpg
If the bolts you have are the ones you purchased from me, I’ll be glad to take them back and refund your money.  Just shoot me an email back to the shop address.
By panel driver - 2 Years Ago
I have seen some posts about the availability of rod bolts for the y block.
I saw this company at the Sema last year. The company is called OptiTorque,
phone number is 315 924 3888 they are located in NY.  They may be of some help.
Just throwing it out there.
