By customline3859 - 3 Years Ago
Hello again. I'm back with more questions. I did some searching through old posts. I also posted some questions on The Hamb. I have the blue thunder intake installed with the RoadDemon carb and a 1" spacer. Throttle rod installed and the TV geometry correction bracket ordered. I was hoping if anyone has competed this swap, how did you mount the TV cable? The intake doesn't have many places to bolt stuff to it. Any advice, photos, part numbers would be greatly appreciated. Attached is a photo of what I'm looking at right now.
By panel driver - 3 Years Ago
Here is a couple pictures of my setup with a 600 holley and a aod trans. The cable bracket for the throttle cable for the aod came from summit its a lokar. Don't have a part number but kit says carbureted and ford efi 86 to 93. You will have to set throttle pressure with a guage and spacer tool, then adjust the throttle kick down cable for proper shifting. Hope this helps.
Sorry for the slow response. I like your kinda hybrid use of the new cable, lokar stuff and using the factory pedal. I ended up with going all lokar. So new pedal, lokar throttle cable and bracket. It took a little bit of work, but it freed up some firewall space.
