Help, B Intake Carb linkage on a 56
http://forums.y-blocksforever.com/Topic162265.aspx
By 63.5xl - 3 Years Ago
Anyone got photos of what they did on their carb linkage after swapping over to a B Intake.
I put a B Intake on my 56 Fairlane 3 speed o/d with a Summit 600 carb. Dealing with the stock funky accelerator mechanism and losing my patience.
By Ted - 3 Years Ago
See if these pictures help.  The bell crank at the firewall was lengthened so that the linkage to the carburetor would be level.
http://forums.y-blocksforever.com/uploads/images/b77ef0f5-c90b-481c-be6c-e200.jpg
http://forums.y-blocksforever.com/uploads/images/1c10de80-2a40-4b13-8f04-1706.jpg
Here’s the link to the original thread.
Need some advice on carburetor linkage... (y-blocksforever.com)
By Joe-JDC - 3 Years Ago
Another Summit carb.http://forums.y-blocksforever.com/uploads/images/dc039787-cfce-4d0a-ae7a-b58c.jpg
S
By paul2748 - 3 Years Ago
did basically the same as Ted did..  Used the stock arm that sticks up, spaced it out a little toward the left to line it up with the carb and ran a rod to the carb..  I did have to add a piece to the stock arm to lengthen it
By Florida_Phil - 3 Years Ago
Thunderbird's are different.  My 55 with a three speed manual and O/D has a B manifold and a Holley carb swap.  The stock linkage worked without modification.
http://forums.y-blocksforever.com/uploads/images/cec27cf1-981c-44e0-9e76-1505.jpg
Stick
