caster/camber
http://forums.y-blocksforever.com/Topic161837.aspx
By Dave V - 4 Years Ago
Are there any options available for a 56 Fairlane to achieve more caster/camber adjustment. I would like some positive caster but unable to do it with shims or I lose my camber ( there are no shims at all on the passenger side upper control arm and it is -.5degree camber) adding shims will make it worse
By miker - 4 Years Ago
That’s not a unique problem, my bird is the same way. IIRC, someone either here or the Fox Barn was able to shim the bottom A frame forward a bit and that helped. There’s something else I can’t quite remember. The A arm bushings mount opposed of the way on a car that they do on a tbird? Reversing one could help? Don’t tear everything apart based on my rusty memory, but maybe someone else will chime in.
Thanks Miker for the input. I was also thinking of trying to shift the lower A arms forward but wasn't sure if it could be done. Was also wondering if a mod could be done to the upper A arm shaft to allow for more shims
