WANTED-PAIR OF 1954 FORD V-8 ENGINE DRIP SPLASH PANS
http://forums.y-blocksforever.com/Topic160002.aspx
By alanfreeman - 4 Years Ago
I'm looking for a pair of original 1954 Ford V-8 engine drip splash pans.  If you have them please email me at alanfreeman54@gmail.com.  Thanks, Alan
By Lou - 4 Years Ago
55 and 56 are the same
By 55blacktie - 4 Years Ago
You might want to talk to Ted.
The rocker drip pans weren't used on 57 Y-blocks. He uses them on engines that were equipped with them (if they still exist), but he doesn't add them. He'll probably tell you they aren't necessary.
By Richard - 4 Years Ago
They may not be necessary but I think Allen is building a correct 54 coup. They have a unique way to mount them. Found mine on eBay and since most people didn’t put them back on they should be out there.  Good luck Allen
They can be handy for more precise setup of rocker arm geometry.
Not sure we are all on the same page.  I thought Allen wanted the front pans attached to the frame behind the radiator
By carl - 4 Years Ago
Richard (2/17/2022)
Not sure we are all on the same page.  I thought Alan wanted the front pans attached to the frame behind the radiator
Correct.  I found him a set   Carl
Still looking for a pair of these '54 Ford V-8 engine drip pans.
