By y-block don - 17 Years Ago
well after attending the c-bus race i have been working hard on getting this beast going these are some older pics but i will get some up to date ones loaded soon
well i have all the paint stripped front and back have to do the doors now filled all the molding holes on the trunk and hood except the ones for the fairlane script will get more pics up soon
By Glen Henderson - 17 Years Ago
These things are like "The Cat eating the grinding stone" you just have too hang in. Takes a lot of time and money, but in the end it is worth it. Good luck with your project.
more pics http://www.picturetrail.com/sfx/album/slideshow/18539796
By rgrove - 17 Years Ago
Im jealous! Our sunliner was REALY bad when I got it. It was a long project for us, but my now wife and I did a body off... it was a LOT of fun, and it was a great project! Yours will be sweet when done. Good luck, and keep the pics coming!
By Gerry - 17 Years Ago
Wondering if you drilled holes in the lower corner of the cross member? The new repo's have a drain hole Ford forgot to put them in. Gerry
i have add some new photos got the car all stripped and in primer i threw it back together to take it to our big carshow here in cinci called the "pumkin run" ive not done any body work yet just stipped and primed and painted the wheels but all in all it shure looks better than it did 9 months ago and it is driveable now i like how the 12$ ebay caps lok on the wheels  lust click on the picturtrail link above
By 55vickey - 17 Years Ago
Hey y-block Don, in looking at your pics of the progression on your 55, almost mimics mine....so many of your pics are identical to mine.......you'll luv er, a great feeling when it's done & not many around. Gary
By mikhett - 16 Years Ago
Hi Mr y block don, Im doing a body off on a 54 mercury monterrey 2 dr ht. I need to get the front crossmember from this place in okla. How did you weld yours in? Mig, Tig, Buzz box? How did you remove it? Did you cut off the angled front frame horn? Thanks a lot.54 Merc Mike
By y-block don - 16 Years Ago
we cut it with a torch slowly then after it was out i took a grinder (small one) and gound off what was left then slid the new one in to where the old one was and took several measurments from side to side and front to back to make shure it was square in the frame then we just migged it in
THANKS MR YD! Mike
