Good Aftermarket Temperature Gauge?
http://forums.y-blocksforever.com/Topic158279.aspx
By Half-dude - 4 Years Ago
Hey guys,
Curious what brand temp gauges you guys use, which ones are rugged and reliable. I'm thinking surely most of you don't use the stock temp gauges that don't even have degrees numbers on them. Also I think I read once that there's more than one place you can put the temp probe rather than the default spot by the throttle lever? Which is the optimal placement?
While I'm asking, any 6volt system amp gauges out there?
By 62bigwindow - 4 Years Ago
I've had good luck with Stewart Warner gauges.
IMO I don’t like added gauges unless I would be redoing my complete dash. I’ve kept all my 56 in perfect working order. I keep a heat gun in the glove box and know what the position of the needle means. I have always kept “idiot” lights also as looking down at gauges can be a distraction.
Our race cars have both (Autometer liquid filled) since neither have recording systems like a RacePack and we have added shut down capabilities under 15 psi for oil.
I have installed an oil pressure gauge under the hood on the same circuit as the light. I also have a volt meter that plugs into the cigar lighter to periodically check voltage.
I have had every brand fail at one time or another with the exception of liquid filled which have never failed.
I don’t think an amp gauge cares on the voltage. The Kaiser/Willys/Jeep sight sells one for $24 and says 6 or 12 volts works on either.
By slumlord444 - 4 Years Ago
Stewart Warner electric gauge. Sending unit in the passenger side head. I run the stock and aftermarket on my 57 T Bird.
By Florida_Phil - 4 Years Ago
My 1955 TBird
http://forums.y-blocksforever.com/uploads/images/7ced80a4-cb84-4061-a4c0-b1e8.jpg
By JimNNN - 4 Years Ago
I use the Longacre AccuTech mechanical temperature gauges on two of my cars with good luck. They aren't small or original looking, but they don't look inappropriate on old cars, either. Underdash mount would work best. They're noticeably more accurate, and probably better quality, than the Bosch mechanical gauge I have on another car.
I agree with others that it makes sense to also keep idiot lights if your car is so equipped, and between the gauges an lights you'll get the info you need. I personally would go with a mechanical gauge over a an electrical gauge - especially if you have a 6 volt vehicle -  but I'm sure there are good elec. gauges out there, too.
aren't the stock gauges electrical?
By Ted - 4 Years Ago
The stock gauges are electrical.  For supplemental gauges my preference lies towards mechanical gauges for both temperature and oil pressure.  For the charging system, I now lean towards a gauge that registers voltage rather than amps.  Here’s a picture showing the amp gauge in my ’55 Ford which simply requires heavy gauge wire as all the electrical must run through the gauge before being used for ignition, lights, blower motor, etc.  A gauge registering voltage does not require that same heavy gauge wiring as does an amp meter.
http://forums.y-blocksforever.com/uploads/images/a4089210-9de1-4447-99cc-25ce.jpg
