By fast freddy - 4 Years Ago
Whats the easiest way to set the valve lash Fred
By Ted - 4 Years Ago
See if this link to a past thread helps. http://forums.y-blocksforever.com/Topic8614.aspx
thanks Ted
By Florida_Phil - 4 Years Ago
I've been using Method #1 for years. Easy Peasy. It helps if you use a remote starter switch.
By 312YBlock - 4 Years Ago
Chart for method 1
I put this chart together when I did mine. Being a thousandth off is not a problem, better to be looser than tight. Looser will give the valve a little time to cool in the seat. 🚗
By 1930artdeco - 4 Years Ago
Yep, I used method #1 and it was super easy. Done in about 20 minutes.
Mike
