Starter Solenoid Test
http://forums.y-blocksforever.com/Topic152128.aspx
By paul2748 - 6 Years Ago
Solenoid off the car (spare).  How can a solenoid be tested?  Can I connected the battery side to a battery, use a jumper to the two small terminals and a test light to the starter side to see if power there?   I will ground it to the negative post of the battery.  This is a original type brown unit.
By Gene Purser - 6 Years Ago
I would ground the mounting bracket and put 12v to the left (facing the solenoid) terminal. Then you should read full continuity between the two large posts. You will also see 12v on the right side terminal as it bypasses ignition resistance to give full battery voltage during starting.
Some solenoid work by having power to the battery post and grounding the small terminal, but I think they all have one small terminal.
