Part numbers
http://forums.y-blocksforever.com/Topic151455.aspx
By 55 GLASS TOP - 5 Years Ago
Hello what does BAE mean when it’s part of a part number  BAE-0000000 thanks
By oldcarmark - 5 Years Ago
Sounds like a Manufacturers casting # not an actual Part#.
How about this number can someone tell me what it is BAE-6404144CP thanks
manufacturers casting # for a Sunvisor Bracket. Ford used to issue catalogs which would show "Casting #' cross reference to actual Ford Part#. Then you could go to Parts Catalog and figure out that Part Application.
By KULTULZ - 5 Years Ago
... can someone tell me what it is BAE-6404144CP
Is this number found on the part itself? It is a FORD ENGINEERING ID NO. BASIC PN 04144 is a VISOR BRACKET.
Most likely, to find the CORRECT SERVICE PN, you will need a period CROSS REFERENCE LIST.
BAE prefix is correct. The four character PN PREFIX did not come into use until all car cataloging began to use the new FORD P&A SYSTEM IN 1959
For illustration purposes only -
http://forums.y-blocksforever.com/uploads/images/f47b5237-e923-4cef-85a1-97d5.jpg
I hope this description was not too long ...
No not to long at all I do not see 64B on your page of body styles.  I was told this part number. Is for a sun visor bracket for a  glasstop Crown  Victoria  body style 64B thanks to everyone.
Have a look at Picture.http://forums.y-blocksforever.com/uploads/images/fef07cd9-a28d-4b58-ae97-eae1.jpg
The last 2 digits on your # and what parts Catalog shows are the same-"CP".  I would tend to agree it fits your Application.
Yours is a 1955 64B, correct?
TRIM CODE 64B visor arm had been removed from service in the 49/59 MPC FINAL ISSUE. Below it still shows in the 1959 edition.
http://forums.y-blocksforever.com/uploads/images/27ae517b-df09-4e06-8087-c010.jpg
... what does BAE mean when it’s part of a part number BAE-0000000
PN PREFIX BAE is 1957 MERC.. BAF IS 1958 MERC.
