By Oldmics - 5 Years Ago
Didnt want to muddle up Cliff"s post so I thought I would start a new thread on this subject.
A quote from the Hoosier below to start things off
" I was going through some old material, and found a copy of a page from some unknown magazine. It indicated that the 285 engine had an Isky E-2. I also found a letter written by the late Richard Gaston. He claimed to have worked at Holman-Moody in the day. He said the 285 came with the E-2 cam from the factory, with Ford markings instead of Isky markings. Then in his next sentence he said that the 290 degree cam had a noticeable lope. The E-2 was a 256 degree cam in those days, with timing events very close to the factory standard 256 degree cam. Rich was retired when he wrote the letter, maybe his memory was a little like mine is, a little fuzzy at times. I wish he were still around, I would try to get more info about the 285. John - "The Hoosier Hurricane"
This 1st version grind of the E2 stick was also the cam that has been identified in the 1956 Mercury M 260 setup.
What I wonder about is that there are some differences between this 56 -M260 (260 H.P. rated engine) and the 57 285 H.P. rated engine.
The differences are both positive and negative.
The two carbs are essentially the same. The intakes were different with the 56 Mercury dual quad intake being a superior flowing unit. The heads were different . 1956 were "C" heads and the 57s were "G" heads. Better flowing 57 "G" heads
Distributor was better in 57 .
If the camshaft used in both the 1956- M 260 engine and the 57s- 285 engine , would the upgrade of the 57s ignition and heads (but not as good of an intake) have made 25 more horsepower than the 56s better intake lesser heads and not as good ignition?
Oldmics
Old Mics: In the materials mentioned above, I also found notes I had made in testing some camshafts I had at the time. I also found a sheet supplied to me by Dennis K. in Michigan. It was a sheet cross referencing engineering numbers and actual part numbers. It showed two engineering numbers that crossed to B7A-6250-C, the blower cam number, namely EDB-D and EDB-E. In my notes I had checked the cam in my blown '57 T-Bird. It had B7A-C stamped on the back of the rear journal, and EDB-D cast into the blank. I had bought the cam new from the local dealer in the late '60s. The timing events were In. 16-74, Ex. 73-17. This is a 270 degree cam, and the numbers are no where close to the E-2 or 290 degree blower cam. Could this have been a left over 285 cam re-boxed and sold as B7A-C? I also had figures for your NOS 260 cam, and they don't match up either. Your cam numbers were listed as In. 22-58, Ex. 66-9, a 260 degree cam. So the cam I have is not a left-over 260 cam either. No wonder no definite answer has surfaced concerning the 285 cam.
John Unfortunatly I am away at the moment and far away from my notes and specs.
Its really great that you kept such detailed notes about these things and is truely helpfull !
I have some of the same information that Dennis offered and I will check the specs on both the EDB- "D" and EDB- "E" versions of the cam.
Probably as you know there were additional EDB suffix versions of the B7A6250-C camshaft.
Those differences were in hardness/cross drilling for oil flow and some other specs that I cant remember at this moment.
I"ll add to this thread when I return home.
Oldmics
By Cliff - 5 Years Ago
Hi guys, this is a broken camshaft that came out of a 1957 D/F car what was used for drag racing, the engine broke a rod in 1957 I have no idea what it maybe, it is not mine, it belongs to the man I bought a lot of blower stuff from a long time ago, he wants to keep the cam, but here are some pictures.
Cliff Is the cam the original cam that the engine came with?
The logo appears to be Harman & Collins.
Can you measure the lift ?
Thanks,Oldmics
Don't know, looks like intake lobe lift .285, exhaust .280 (with a caliper) I know this was a phase 1 car and was bought to race from Maywood Bell Ford in 12/1956
Here's a letter I have.
I also have that letter.
Any sort of Y Block information coming from John Wilson would be questionable in my opinion!
Oldmics
Hoosier
I finally got back to my notes and the figures you state regarding the B7A - C camshaft you documented are not to be found in any of my Ford info.
Do you still have this camshaft in one of your engines? It just may be the 285 unit !
Oldmics
By PF Arcand - 5 Years Ago
For what it's worth, further on the cam spec's dilemma . By chance, I came across a re print artical in Y-Block magazine, issue 141, August 2017. In the blurb by the then HRM's Racer Brown, apparently in 1969, he mentions while answering an enquiry (about 1956's) that 57's likely had a better Cam in the E code cars available, an " E-2 Isky" for the 285 H.P. versions.. He also stated that NASCAR allowed the Dual 4 Bbl setup as stock in 1956, but NHRA did not in Fords, (apparently it was an over the counter, dealer install item) only allowed in Mercury's.. How many 285 H.P. units were built, I don't know, but I do have a copy of a 1957 Ford newspaper Ad, that includes a reference to the 285 H.P. engine..
Old Mics:
Sorry I didn't see your last post earlier. Yes, I still have that cam in my blown (not factory, darn it) '57 Bird.. I have drag raced it a few times in some Pure Stock races, and Gordon Payne has raced it in some Y-Block Shootout races. It is streetable with an FMX transmission and stock converter. Idle RPM in neutral has to be about 1000, but with the vacuum modulator on the FMX the shift from park or neutral into Drive and Reverse is nice and soft.
