By johns55ford - 6 Years Ago
What is the mfg. number on Exhaust headers for 1955 Ford with 292 duals ? John Henry
By Ted - 6 Years Ago
The exhaust manifold casting numbers for the ’55 Fords with duals should read ECH-9430-A for the right side and ECH-9431-A for the left side. On your brake lights, did you check that the hydraulic switch is functioning? On your turn signals, did you replace the signal flasher so it is also 12 volts?
