Spark Plugs 2
http://forums.y-blocksforever.com/Topic140428.aspx
By paul2748 - 8 Years Ago
Is the Motorcraft BF82 the equivalent of Autolite 46 ?  Heat range?  Other??
By KULTULZ - 8 Years Ago
http://www.sparkplug-crossreference.com/convert/AUTOLITE/46
By Tedster - 8 Years Ago
paul2748 (10/16/2018)
If the spark plug cross-reference website can be believed, yes. If you play around and plug (heh) different plug #s into the website you'll get a different answer depending on which direction you're coming from. Manufacturers now sometimes claim that one plug can equal 2 or 3 heat ranges, conveniently having removed some of the offerings in their lineup. If you're picky on heat range, it's tough to beat NGK as they offer a full spread, plugs with a "5" in their nomenclature are midrange and as the numbers get higher they get colder in heat range.
Thank you both
Will an AUTOLITE (but won't) CHANGEOVER CATALOG meet your specs Ted?
http://www.autolite.com/media/11790/auto_crossref_0311_0.pdf
