By trodom - 7 Years Ago
wanted exhaust manifolds for 292 ford v8
We need more info. Do you want passenger car manifolds for dual exhaust, '57 and later or pre-'57, T-Bird '55 or ''56 or '57, passenger car or truck single exhaust with the crossover pipe at the front of the engine, or truck rams horn? Lot of choices.
Sorry, I hadn't seen your other post on the engine for sale ad. I'll look and see if I have a pair that are usable.
58 ford truck original with cross over pipe ; prefer to go back with cross over pipe but if cant would go with duals not headers like the rams no
By Ted - 7 Years Ago
I also have several sets of those manifolds for the single exhaust with the topside crossover. There are also some of the crossover pipes in reasonably good condition sitting here. You don’t mention where you’re at so shipping is going to be a major cost consideration. If you’re located in the Central Texas neighborhood, then I can fix you up. I don’t see a front license plate on the truck in the picture so I suspect you’re not in Texas. I’ll let Carl or John have first shot at this if shipping is going to be involved.
Passenger car dual manifold will not work on your truck. The outlet on the manifold and the steering box are not good friends. On my truck I have a RH passenger manifold on the left side, which exits at the front of the engine. It is an easy routing for the exhaust pipe from that point. I defer to Ted or Carl on the sale, Carl's shipping cost would be pretty similar to mine. He's in Ohio, I'm in Indiana.
I live in chester sc 29706 can u send pictures to my email teddyodom1970@yahoo.com thanks teddy odom
do you mind sending pictures of your exhaust set up
I live in chester sc 29706 can you e mail pictures teddyodom1970@yahoo.com thanks
By carl - 7 Years Ago
I will send some pictures tomorrow Carl
thanks carl
pictures sent Carl
By PF Arcand - 7 Years Ago
If you really want to go back to the crossover exhaust o.k. but if you want to improve the engine's output some, that setup is a power robber. Don't know why Ford chose to use that on so many models? Testing by our moderator,Ted, showed it to be the poorest performer of all the several exhaust systems tested..
can you show pictures of your exhaust manifold set up thanks tr odom
