            Why would a 292 stock "pop" out a pushrod?  Had to fish it out of the valley.
            By oldcarmark - 7 Years Ago
            Sticky Valve, Excess Lash, Worn Rocker, Worn Pushrod End.
            By miker - 7 Years Ago
            Or, you need to shift sooner.  Threw more than one from floating the valves.
            Happened to me once too. No reason why, did not hurt anything either.
            By GREENBIRD56 - 7 Years Ago
            Unleaded gas cut with 10% alcohol - dry valve guides.
            By Tedster - 7 Years Ago
            4 fl. oz ratio MMO per 10 gallons gasoline is good insurance against stuck lifters, valves, rings, etc. At least, that's the story. It certainly can't hurt anything.
             It occurred while cranking.  I heard loud clink/snapping sound.  I think it was stuck valve.  Sprayed all springs with Marvel.  Seems OK.
            I'll try Marvel Mystery in gas tank.  Seems ok, only happened once.
            How old was the gas in the tank when it last ran?
            By Ted - 7 Years Ago
             55charliebird (5/15/2018)  It occurred while cranking.  I heard loud clink/snapping sound.  I think it was stuck valve.  Sprayed all springs with Marvel.  Seems OK. In your case, odds are in favor of the pushrod not being properly seated in the ‘divot’ in the top of the lifter; the pushrod simply fell off the top edge of the lifter when you attempted to start the engine.  A sticking valve will continue to give problems after this.  If you have 3 month or older fuel in the gas tank, then the potential is there for the intake valves to stick within their guides and especially when the guides are new.  Old fuel will allow the engine to start up but once it cools and a restart is attempted, the old fuel does leave a gummy residue (varnish) in the guides which will stick the valves when attempting to restart the engine.  I’ve seen all eight intake pushrods bend at the same time when this occurs but always happens after the first run in.
             I was using fresh gas from a bottle.  God knows when fresh gas was put in that tank.  I bought the car from 3rd owner who had it 43 years.  I don't dare feed fresh gas thru the tank w/o removing it and flush it.
             Thanks, good advice.  Makes me want to run a smaller tank because of the limited amount of usage.
