            By Melly - 7 Years Ago
            When removing my 55 radio which was not connected.  I noticed on driver side of radio a Black wire with fuse link, and also a white wire. I figure the black wire goes to Battery.  Have know idea where the White wire would connect to.  Any help on what this white wire is and where it would connect to?
            By Ted - 7 Years Ago
            Probably the wire for lighting the radio dial and that would hook up to the instrument lights.
            I thought of that, and makes sense.  My old memory seems to think the radio light up when turned on.  Can't seem to find where it might have been connected on my org. harness. And have no way to test, as was converted to 12v.  Maybe I will try Battery charger on 6v.  thanks
            By MoonShadow - 7 Years Ago
            The light wire to the radio is usually a small diameter wire. If you have a simple circuit tester just turn on the lights and see if the small one has power. Done!
