| By Florida_Phil - 8 Years Ago |
		| I am installing a 1957 312 Holley iron intake and Holley carb on my 1955 292 Thunderbird.  I believe the intake came off a 1957 "D" code passenger car. Everything seems to fit fine, but I'm having a problem with hood clearance.   I tried using a small block Ford HiPo air cleaner, but it's too wide.  I would like a nostalgia type air cleaner that looks 60s correct.  Something clean and small enough to clear.  Anyone ideas?
		| By miker - 8 Years Ago |
		| Some one here used the dual quad version of these, and I tthought they looked pretty good.  This is the single quad version.  I also modified my 55 a/c to use a standard base plate and element some years ago.  PM me if you're interested.
 http://www.ebay.com/itm/Vintage-4-Barrel-Air-Cleaner-Badger-Scta-Hotrod-Kustom-5-1-8-/222597712985?hash=item33d3db8c59:g:4y0AAOSwCU1YodHa
		| By blockhead2 - 8 Years Ago |
		| There should be no problem if you are using the stock parts and original air cleaner.  The only things I can think of that would affect that is the carb spacer and engine mounts.  Are you using the original Holley carb or a replacement?  Be careful with the air cleaner stud or you may dimple the hood!  The original air cleaner would look best and take advantage of the fresh air intake.
 GL,
 Bill A
 55 Tbird
		| By dbird - 8 Years Ago |
		| I have an aftermarket 14inch diameter, 3 inch high air cleaner with a recessed base in my 55 'Bird.  Clearance is tight at 5/8 inch, but that's with a Mummert intake which I think is his taller one, not the shorter Thunderbird version, not totally sure as I bought it used. |
		| The EBay air cleaner is exactly the one I was looking. A little pricey at $100.  I think we used to pay $10 for those from JC Witney back in the day.  I don't care for the stock helmet air cleaner.  It looks silly in my opinion.  To each his own.  Thank You!!
		| By famdoc3 - 8 Years Ago |
		| Use the 57 T'bird base air cleaner 2barrel or 4 barrel the top is designed for the modern Holley not the old teapot so won't have that "helmet" look you don't like and should clear easily.  MIKE |
		| By Brent - 6 Years Ago |
		| Found this article re air cleaner/hp : https://www.hotrod.com/articles/air-cleaner-assembly/
 Has anyone fit the K&N Flow Control? Seems there is a combination that will work.
 https://www.knfilters.com/racing/flowdimen.htm?pkid=6343082&rw=2
		| By charliemccraney - 6 Years Ago |
		| The K&N stub stacks work.  The entire aircleaner is taking that to the next level but I haven't heard reviews.  If $100 is pricey, then Flow Control is not even on the table. |
