Oil pressure gauge
http://forums.y-blocksforever.com/Topic131163.aspx
By LuciFord - 8 Years Ago
What's the Best place to plumb an oil pressure gauge from? Thank you!
Most common/simplest is to instal a brass 'T' fitting between stock sensor switch & block. Plastic or copper line is cheapest, but I opted for one of the reinforced hose kits sold by aftermarket speed equip. suppliers.
By 62bigwindow - 8 Years Ago
That location didn't work on my car. The clutch bracket wouldn't allow it. There is a plug in the block close to the oil filter. I put mine there.
By miker - 8 Years Ago
There's a couple more plugs in line forward of that. Assuming they come out, use what's easiest to get to.
By Ted - 8 Years Ago
On the dyno, I typically use the oil galley plug that aligns with the #2 main for the oil pressure and oil temperature hookup.  That location is used simply due to it clearing some of the other dyno hook ups.  Any of those ¼”NPT plugs on the oil filter side of the block would be a suitable location to get an oil pressure reading.
http://forums.y-blocksforever.com/uploads/images/cc78d85d-f54a-44ef-b1b7-3083.jpg
By PF Arcand - 8 Years Ago
Plastic oil lines have to be kept well away from the exhaust system for obvious reasons. If using copper it's a good idea to make a loop in the line for vibration failure resistance..
