By rexbd - 9 Years Ago
FINALLY, getting close to having the Tbird done!!! I need to source a tach drive distributor for a 57 set up. My tbird is a 55 but I have gone to a different intake and carb so need to change out the distributor. I cant find anyone who sells a new tach drive dist for the 57 tbird. Any help would be appreciated
Rex
I imagine this would just need to be recurved
http://www.ebay.com/itm/57-Ford-Thunderbird-E-Code-Dual-Quad-Tach-Drive-Distributor-312-Y-Block-T-Bird-/152395612000?hash=item237b7c7f60:g:o9EAAOSw44BYeaYz&vxp=mtr
You can also use a standard Y block distributor and convert to an electronic tach. I don't know the details, but I know people have done it and the cost will be far less than an original tach drive distributor.
and a mortgage, wow. Plan B
By DANIEL TINDER - 9 Years Ago
The T-Bird parts suppliers sell tach-drive Mallory distributors.
By paul2748 - 9 Years Ago
Check with the Tbird parts suppliers, especially Hill's. A lot of them sell used parts. Be prepared to spend some 500-600 bucks, possibly more, for one.
The one shown is for an EBird. The regular 57 DBird dizzy's go for a lot less.
By NoShortcuts - 9 Years Ago
Click the link below that shows a '57 'Bird distributor that was sold on eBay just a short time ago. Note: 9 people bid! http://www.ebay.com/itm/57-Ford-Thunderbird-Tach-Drive-Distributor-T-Bird-TBird-Y-Block-YBlock-312-292-/152371359894?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=qt7za7DJ35FJSL1yLD9x9FmKIEc%253D&orig_cvip=true&rt=nc
As Paul said, it's a bit less pricey than the E code unit that is presently being offered. The thing is that other than the ID housing code, there's not alot of difference between a C or D code 'Bird distributor and an E code unit. The distributor plates are for single point ignition, and the distributor cam is the same. Yes, one centrifugal advance spring is different and something in the vacuum advance chamber is different (the spring or the # of shims used, not sure), BUT otherwise it's ALL the same!
I'm glad I don't have anything more than a driver!
By miker - 9 Years Ago
I have a 3 3/8" Stewart Warner mechanical tach. I'm pretty sure the electronic ones use the same case. You pry the bezel off, cafefully grind the lip off down to the case (or can) size, and it slips right into the stock 'bird tach bezel. Make a U bracket for the back, carefully sand the faceplate down to fit, and you're done. Electronic tach, cheap. It won't look stock, because they don't make 5000 rpm tachs with the sweep on a bird. But it fits, and works. Doane Spencer put a 9000 rpm SW tach in his 55, using a mechanical drive aftermarket dizzy. He had an 8000 rpm Y block. Far beyond most of our capabilities. That's where I got the idea.
