By cmallory - 9 Years Ago
I have a complete 312 with ford-o-matic and all linkages out of a '55 Tbird. I also have the manual that was in a crate. Located in Houston. Make me an offer.
By carl - 9 Years Ago
Are you sure its a 312,but hey all y blocks are 312 lol Carl
By texkbc - 9 Years Ago
does this engine run? I am interested Bryan 254-722-3014 in Texas
By PF Arcand - 9 Years Ago
As Carl alluded too, if it's an original 1955 T-bird engine, it's not a 312. They were 292s. To determine what it is, requires checking the end of the crankshaft flange, where a single shallow 5/16" diameter raised dot may be found. If not found, then it will require removing the oil pan. If the rod ends are marked ECZ, then it's a 312. If marked EBU, it's a 292 or even could be a 272. Either is o.k., but don't pay a substantial price for a non 312.. On the other hand, 312s are much more likely to have block casting cracks then the others, which may render the block as unusable.. So, proceed accordingly..
