Pulley removal
http://forums.y-blocksforever.com/Topic122802.aspx
By Kahuna - 9 Years Ago
What is involved in removing the front pulley(s) & damper on a 292 Y Block?
I can't seem to remove the front bolt & wonder what the process is?
Jim
Remove the center bolt.  If any accessory pulley is installed, remove that.  Use a damper puller to pull the damper.  To install, you need a damper installer.  In case you are wondering, a hammer is not an installer.
To remove the bolt
If equipped with a manual transmission, put it in gear, put on the brake, chock the wheels and use a breaker bar or long handled 1/2" drive ratchet.
If auto transmission, use the breaker bar and get in a position where you can pull on it hard and release repeatedly.  That usually works it off.  Don't use an impact wrench.
If on an engine stand, use a big screw driver to wedge into the teeth of the flywheel and lock it in place or thread in 2 flywheel bolts and use a long wrench to hold the crank from turning or get a proper flywheel turning tool to hold the flywheel in place.
By miker - 9 Years Ago
I stole this off the HAMB. I'm not this clever
By paul2748 - 9 Years Ago
Charlie - why do you advise against using an impact wrench.  On hard to release bolts, I have used an impact wrench with much success
Cast cranks can break easily with an impact wrench.
Thanks Guys for the suggestions.
I'll have to try Charlie's method as engine is in the car and is an auto trans
Hope it works, as I've got to get it off
Jim
OK
I got the bolt out using Charlie's method.
Now, how does the damper get removed?
Jim
By oldcarmark - 9 Years Ago
You need to get a Puller. Same Type used on Steering Wheels. Bolts on with the existing threaded Holes in the Damper.
Thanks Mark
I'll try to get it off today.
Thanks again
Jim
If it's a pulley on a Tbird the steering wheel type puller will not work
You will need a tool to re-install the Damper too. Does your local Auto Parts Store have a Loan-a-Tool program? DO NOT use a Hammer to re-install.
Thanks Mark
That was going to be my next question?
I got it off this am, now to get it back on
Jim
There is a similar Tool to reinstall by threading into the threads where You removed the retaining  Bolt from.Make sure it is threaded in enough that You don't pull the Threads out of the Crankshaft before You start to pull  the Damper on.
Lisle 53460 should work well.  It comes with a spacer which should work well with the relatively deep damper that a y block has.
http://www.lislecorp.com/divisions/products/?product=623
The main thing with the installer is that it has a 9/16-18 adapter.  Many do not.
Thanks again, Charlie
I'll get it done
Jim
Another way to do it:
Get a longer bolt and draw it in enough so that you can use the regular bolt to finish it.  Just don't bottom out the longer bolt in the crank.
Hi Paul
That's exactly how I'm planning on doing it.
Jim
Pulley restored, Yeah
Jim
