By cokefirst - 9 Years Ago
I have a 1957 Skyliner with factory Select Aire. It has a 7 blade direct drive fan run off the water pump. at 70 mph it sounds like an airplane. Is there a way of using a fan clutch and different fan to reduce the noise and the horsepower drain?
By miker - 9 Years Ago
Start here, Greenbird post. That clutch fits the w/p hub. You fan may work as is, don't know.
http://forums.y-blocksforever.com/Topic122011.aspx
By GREENBIRD56 - 9 Years Ago
Hayden has an online available PDF catalog of the fan clutches. Take a close look at how much room you have between the waterpump pulley flange face - and the radiator - and go from there. My Thunderbird had plenty of room to work with - sedans maybe not so much. The #2797 severe duty clutch I ended up with, was original equipment to several Ford and GM applications. As you can see below, there must be 3-3/4 inches + a clearance, between the pump flange and the inside face of the radiator.
I can see why it works on the Thunderbird, lots of room between the engine and radiator. Unfortunately, with the A/C compressor sitting forward and the radiator so close, there is not enough room between the back side of the fan clutch and the flywheel of the compressor for a fan to fit. I put in a slightly oversized radiator and had to trim 1/4" off the fan spacer to get the original set up to work. Much thanks for your thoughts!!
