Ford o matic
http://forums.y-blocksforever.com/Topic121623.aspx
By 54 dan - 9 Years Ago
Just bought a 54 customline, just wondering how hard it is ,or if its worth reconditioning the ford o matic ,or just going c4
By Lou - 9 Years Ago
The 54 like the 55 Ford had a air cooled Ford -0-matic , if it's working OK leave well enough alone, if the trans needs rebuilding (Other than seals) go for 57 up Ford-0-matic or a C4.
By paul2748 - 9 Years Ago
http://forums.y-blocksforever.com/uploads/images/0489f5fd-8d9a-46d2-b581-6f37.jpgTough call.  The cost of a rebuild on the Fordo is probably  about 600 bucks.  You can look up the cost of the C4 kit.  For the money to buy and install the kit and C4  you get a better , more modern trans, that any shop can fix, is lighter, may give you better mileage and is a true operating  three speed from take off.
What is wrong with your present trans that it needs rebuilding?
By Pete 55Tbird - 9 Years Ago
Without knowing much more about your car, what you plan to do with it and your ability to do your own mechanical work it is not possible to give you any useful advice. I do know the FOM is very strong and VERY HEAVY ( 150 + LBS ) . It will cost at least $ 1500 to convert to a C4 and only you can tell if it will be worth it. If the FOM is working now and only leaking, just drive it for a while till you see how much time and money the car is worth. Pete
By Cliff - 9 Years Ago
Hi, a  Cruise-O-Matic ( or FMX ) fits the car, gets you a modern transmission and costs a lot less, however it weighs about 60 lbs more.
Thanks for info guys,think im going c4 route with adapter kit
