By 30 coupe - 9 Years Ago
   I am going to try and post some pictures of the oil pan on my 30 coupe. I hope some one can tell me the original application, as I would like to find another like it. I know that the one baffle in it was added by someone and is not stock, or at least it looks like it was added. any help would be appreciated. I have other rear sump pans, but they all have a "double step " where this one is a single step. thanks, -----Jim
Well the text did not appear where I wanted it to, guess I will have to work on my computer skills-------Jim
By NoShortcuts - 9 Years Ago
Hmmmmm... As you say, a baffle has been added. I believe that it is Ford '55-'57 T-Bird only y-block rear sump oil pan.
By miker - 9 Years Ago
Well, the pickup truck pan on my 32 has a small second step. And while that looks like a bird pan, I think it's too deep in front. The birds still in off site winter storage so I can't be sure. Didn't they make some heavier truck pans that held more oil, for like a 1.5 ton or up? Or stationary engines. I don't know what the marine pan looked like, but that's another possibility.
By carl - 9 Years Ago
It looks like the heavy duty truck pan I have,but hard to tell without getting a measurement on the sump depth Carl
By Genuinerod - 9 Years Ago
The pan is for 55/57 T-Bird. Rear sump, rear angled drain plug---T-Bird. Can be used on other engines.
AH! I'm wrong! Miker and Carl know better. Miker's right. -It's too deep on the front end to be a 'Bird pan. Me thinks the HotRod Reverend had one just like this for sale a hundred years ago or so. IF I'm right, they hold more oil (an extra quart?) than the 'Bird, passenger car, and standard rear sump truck oil pan.
Thanks for catching my error!
By thundercat - 9 Years Ago
I just disassembled a 1963 super-duty that has a pan like that . I will try to upload pictures. It measures 6" deep.
sorry about previous picture..
I think Thundercat has what you're looking for. Click the eBay link below to see the one Miker was describing with the step in the bottom.
http://www.ebay.com/itm/1963-Ford-F100-F250-Y-Block-Oil-Pan-/331769840499?hash=item4d3f060373:g:2psAAOSwHnFVwAkT
Hope this helps to nail it down for you.
Thundercat, are you interested in selling your oil pan ? I have been thinking of trying to find another one. I have to go through my parts that I have stashed at my brothers place to see if I have another one. If I do not I may be interested in yours if it is for sale. how bad is the rust on the pan?
I may be interested in selling.. I just disassembled 2 weeks ago and have not cleaned up yet. I have to wait til snow goes away to pressure wash outside. lots of parts to clean as soon as Spring arrives. I used a Tbird pan on my 32 Ford that was mint if I had had something like this I wouldn't have used it.. I didn't think a pickup was deep enough and was in a rush to get running and didn't take time to make a pan.. The 63 Super Duty was original std-std crank with 3-63 date on ford bearings Standard bore cylinders in a dump truck so I'm pretty sure its original pan also..Looks like never apart.. Regards Steve
Thundercat, no hurry, I know what it is like, I live in Alaska. I will be away from home for awhile, maybe as long as the 1st week in may. I will still be able to get internet, and will ck in here often. let me know if you decide to sell. you ( and anyone else from the forum ) can contact me directly through my e-mail if you would rather communicate that way. mod1890@gci.net . I will be trying to get a tan in Texas while I am gone. what part of Pa. are you located in? I was born in Lancaster, and spent my younger years in the Manheim and Mt.Joy/ Elizabethtown area.-----Jim
My last statement came out wrong . I would have used the truck pan and saved the Tbird pan. I will let you know if I decide to sell it. [ Not only can I not type i'm also forgetful drop me a message in a month or 2] regards Steve
Mars is in Western Pa. 30 miles north of Pittsburgh.
Thanks, Thundercat, I will keep you in mind. thanks for the information, and pictures it helps a lot.------Jim
By Ted - 9 Years Ago
30 coupe (2/24/2016)
 I am going to try and post some pictures of the oil pan on my 30 coupe. I hope some one can tell me the original application, as I would like to find another like it. I know that the one baffle in it was added by someone and is not stock, or at least it looks like it was added. any help would be appreciated. I have other rear sump pans, but they all have a "double step " where this one is a single step. thanks, -----Jim That’s the HD truck pan. 7 quarts with filter.
Thanks for the info Ted, I appreciate it. now that I know what I am looking for, my search may be a little easier. Now I just have to try and find one that is not rusty and not dented.
i have a truck engine in my 47 mercf47,the pan is similer in apearance ,but has a door that opens when going up a hill allowing more oil to pump,the door closes when stoping radicley or going down a steep hill.years ago had 2 frends with ford trucks .1 56 1962,both had the light come on (low oil pressure) when stoping or starting fast. the fix was instaling the heavey truck flaper
By 314 - 9 Years Ago
these bases are very common i have 3 or 4..there are many truck bases at least 4.
