By wildlogger - 10 Years Ago
my 56 has 2 outlets on the core to the left of heater core but above right is a heater outlet with a Y what is that, I ve looked at fotos some cars have it some don't thanx
By Canadian Hot Rodder - 10 Years Ago
Can you post a pic? A previous owner may have installed a fitting, possibly to flush the system?
By crownvic55 - 10 Years Ago
That Y is the heater control valve to let the water flow thru the heater core. Some cars have a vacuum operated valve mounted in the intake manifold.
By Daniel Jessup - 10 Years Ago
crownvic55 (11/20/2015)
ditto.
That unit is basically a thermostatic control. There is a coil attached that sits in the air plenum as well to make the valve open and close according to what you are calling for on the controls.
By Kahuna - 10 Years Ago
I'd sure like to see a picture of that
I ll snap a photo of it!
Here are a couple of pics. Hope these help. Ben
Interesting, I've never seen that, only the valve on the intake. manifold. is that vacuum or cable operated?
By Ted - 10 Years Ago
My 1955 Ford station wagon with factory installed air conditioning had that same heater hose Y on it. Is your car a factory air car?
No, my car (55) has no air conditioning. Car in family since new so this is the way it came. Also had a 56 292 with same valve. Valve is cable operated and as Dan said it has a thermostatic coil to regulate the flow of hot water depending on where the cable lever is set.
By MoonShadow - 10 Years Ago
So the heat cable controls a valve on the inside of the firewall that this connects to. Possibly a replacement for the vacuum valve in the heater duct?
By oldcarmark - 10 Years Ago
I believe that type of Heater setup is called a recirculating type. Supposed to be more efficient and it is controlled by a bi-metallic spring in the heater Case. I have the same setup on mine and it was never an A/C Car. Not sure why some Cars have the regular Heater and some the re-circulating type. Was never an Option as far as I know.
By 57RancheroJim - 10 Years Ago
I wonder if some were factory installed and some dealer installed ? I know that sometimes people would pick a car that was on the lot rather then ordering one and the dealers would install options that the people wanted that may not have been on the car.
By junkyardjeff - 10 Years Ago
My 55 sunliner had that style of heater control valve but it broke so I installed a 65 to 72 truck style since I was in a hurry to get it fixed.
By 82warren - 10 Years Ago
Yea, and these mechanical valves are getting old, the rubber seal maybe leaking but ... if yours is not leaking and looks good it's probably fine. It's run by a cable to your heater control. There really aren't new ones to be had, there was a guy making the rubber part new so it was possible to rebuild them. If your mechanical heater control is no good, just eliminate it, put in a shut-off valve. I hate heaters blowing hot air in summer. 82warren
