WANTED: THREE GOOD USED PUSHRODS FOR 239 OR 256 Y=BLOCK
http://forums.y-blocksforever.com/Topic115552.aspx
By alanfreeman - 11 Years Ago
Does anyone have a few extra original  239/256 pushrods they want to sell?  I had two that were bent and one that was galled.  I replaced them with three new Elgin 292 pushrods although I noticed that the length was slightly different.  They worked but all three are not oiling down the pushrods for some reason although there is oil to each of those rockers and the other five original pushrods on that side are oiling.    Thanks, Alan S. Freeman
By carl - 11 Years Ago
alanfreeman (6/26/2015)
Alan can you give me a length on the pushrods you need,i have a lot of good used ones but not sure which engine the came from  Carl
By Ted - 11 Years Ago
Like Carl, I have a multitude of used pushrods but need to know what length pushrods you need.  If Carl cannot provide what you need, then I probably can.  I’m assuming you are addressing the oiling problem at the rockers before adding any more pushrods?
Ted, there is really no problem with oiling at the rockers on this engine. .  After I noticed that the three new replacement pushrods were dry with the engine running,  I switched them with three original ones from that side of the engine.  The lack of oiling followed the switch yet the original pushrods were oiling where they had not been with the replacement ones.  I looked up the Elgin part # on the replacements I had used and they were indeed for '56-'64 Y-Blocks not the earlier engines.  The engine ran fine with the replacements but just had no oiling down the pushrod.....maybe the cup at the rocker end is shaped differently????  As I recall, the '54 rocker arms are different in some way than the later ones.  I will measure the length of one of the originals.  Alan
The length of the original 256 pushrods is 8 3/16" (8.1875 inches).  Alan
alanfreeman (6/27/2015)
I will check tomorrow and see if I have some  Carl
Alan    This is the measurement of the pushrods I have  8 3/16 long  Ball is .359  Cup is .520  not sure what they came off of,if you think they will work for you I will let you have all 16 of them for shipping cost,i will probably never need them  Carl
Hi Carl.  Those sound like the right ones.  I appreciate the offer.  My email address is alanfreeman54@gmail.com.  Please email me with the amount of the shipping and I will give you my mailing address.  My Zip Code is 93030 (California).  Do you have a Paypal account to which I could send the money for shipping?  ?  Thanks again, Alan
By PF Arcand - 11 Years Ago
Is it me, I'm just not understanding Alan's explanation of  what's happening to his engine?.. It's getting oil to the top, but it's not finding it's way down the pushrods? If that's what's happening (?)  my first thought is that the little oiling ports at the pushrod end of the rockers are plugged.. yes no??
I checked the holes in the rockers and they were not plugged.  The only time I was getting no oil down the pushods was when I tried to use the new replacement 56 and later 292 312 pushrods and then there was no oiling on those rockers.  When I switched around the new and old original pushrods wherever I put the the new ones there was no oiling.  Maybe there is some difference in the shape of the end socket between the '54/'55 pushrods and the later ones?  Alan
