Dove rocker arm specifics
Posted By slumlord444 13 Years Ago
Posted 13 Years Ago
Getting partial sets or individual Y rockers from Dove is not expected to be a problem.  Just give them a call and talk to them concerning your needs.  If there is a problem in doing this, just give me a shout and I’ll see what I can do.  The aforementioned problem with the Dove adjusters breaking was with a particular batch of adjusters made from improperly heat treated material.  While it was embarrassing for Dove that this happened, they went out of their way to supply me an adequate number of correctly heat treated adjusters so that I could get with customers and get those faulty adjusters swapped out.  That issue hasn’t surfaced in quite awhile now.
The Harland Sharp roller rocker setup for the aluminum heads uses the same number of adjuster offsets as the Dove units.  The setup on the shafts ends up being similar.  For the aluminum heads, I am having to machine 0.080” off of one side of the second from the right supplied rocker stand in order to maintain proper valve stem tip alignment.  Not a biggie on this end as I perform that operation in a lathe which also allows me to put the step back on the edge of that particular stand for rocker side clearance.
Regarding using solid spacers or springs between the roller rockers, I’ve been both ways.  For whatever reason, the rocker assemblies using springs appear to have a slight horsepower advantage over the rocker assemblies using spacers.  Having a slight preload on the rockers seems to work in favor of controlling some unwanted movement in that area.
Here’s a picture of the Dove Rockers on the aluminum heads.  This particular set is using spacers between the rockers.
Here’s a picture of the Harland Sharp rockers on the aluminum heads.  This particular set uses springs between the rockers.
Missouri Mike
Posted 13 Years Ago
Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)
Posts: 210, Visits: 1.2K
    Will the Harland Sharp or Dove roller rockers fit under the older valve covers like Fenton or Weiand?????
    Missouri Mike
I'd rather be lucky than good.................
    but good ain't bad!!
aussiebill
Posted 13 Years Ago
Posts: 1.8K, Visits: 11.4K
TED, as allways a great informative reply re the rocker arms, i,ll call Dove and go from there, I like the ex ports on those heads , thank you again from all of us. regards bill.Smile
 Down Under, Australia
Talkwrench
Posted 13 Years Ago
Posts: 898, Visits: 23.2K
Ooohhh momma.. one day I'll have a set w00t
Posted 13 Years Ago
Last Active: 4 hours ago
Posts: 4.6K, Visits: 38.4K
Gee at my current age I feel really blessed to still be dreaming of head(S). Tongue Chuck
slumlord444
Posted 13 Years Ago
Posts: 1.2K, Visits: 137.8K
Great photos. I am assuming that the T-Bird valve covers will fit with the Dove setup? One more question. Is drilling the holes in the block and heads for cooling between the middle cylinders advisable with the aluminium heads?
aussiebill
Posted 13 Years Ago
Talkwrench (2/13/2012)
Well, you mention you,re going to the states, there couldnt be a better opportunity while the dollar is the best its been, you could bring them home in suit cases, looks like a golden opportunity to me.Smile
Posted 13 Years Ago
slumlord444 (2/13/2012)
There have been no problems with fitment of the Dove or Harland Sharp roller rocker arm assemblies under the stock or Thunderbird valve covers to date.
I’m going out of my way to plug the holes in the blocks when they are present. On my end, no steam hole venting is required with standard height radiators.
Here are links to a couple of other threads on the subject.
http://forums.y-blocksforever.com/Topic18743.aspx
http://forums.y-blocksforever.com/Topic47206.aspx
Performing a search will bring up more on the topic.
Vic Correnti
Posted 13 Years Ago
Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)
Posts: 347, Visits: 12.3K
For my .02 cents worth the spacers are a lot of trouble getting the side clearance required between them. Then if you take the assembly off and put them back on you have to fiddle around as you bolt them back down to get the side clearance right again. More HP with springs and no shimming sounds like a no brainer to me.
slumlord444
Posted 13 Years Ago
Planing on going with the springs. Hope to call Dove tomorrow and order them. When I talked to them a week or two back they were out of stock but planed to have them soon. As always, great information here. Thanks to Ted and everyone else. Now if I can just figure out the piston rings-----
