Taff
Visits: 100
hi all, now I have the y block in my galaxie turning fairly freely, my thoughts are turning to getting her running. to check timing, my instinct is to get the motor to no1 TDC on compression stroke, is this correct? also, which is considered to be number 1 cylinder on these engines, front of the left or right bank? Thanks agin for your patience, this y-block stuff is all new to a guy who loves chevy straight six's
Cheers, Taff
1959 Ford Galaxie 2dr sedan, 292 (just woken up after a 38 year sleep!)
Last Active: 16 minutes ago
Posts: 3.5K,
Visits: 469.2K
No 1 is on passenger side, front. Should have a number on the intake
Pete 55Tbird
Visits: 93.2K
Taff A work of caution as the blokes on this forum do not care for Chevys even the sixes. Your cars number one cylinder is right front or passenger side LHD car. The distributor rotates counclockwise. The firing order is 1 5 4 8 6 3 7 2 ! THANK YOU AUSSIE BILL.
What have you replaced/renewed and are parts hard for you to get. Good luck Pete Getting late, sorry
jonnireb
Visits: 1.4K
Yeah, you're right,get no.1 piston at tdc. No 1 cylinder is front cyl. right bank.
55f100West Monroe,La.
rick55
Visits: 4.4K
Hopefully this little pic makes it all clear Regards
Rick - West Australia Do Y Blocks Downunder run upside down? Gravity Sucks!!
aussiebill
Posts: 1.8K,
Visits: 11.4K
Pete 55Tbird (2/26/2012)
Taff A work of caution as the blokes on this forum do not care for Chevys even the sixes. Your cars number one cylinder is right front or passenger side LHD car. The distributor rotates counclockwise. The firing order is 1-5-4-2-6-3-7-8 What have you replaced/renewed and are parts hard for you to get. Good luck Pete Correct fireing order is 1 5 4 8 6 3 7 2 !
snowcone
Visits: 5.9K
Is there any particular reason why number 1 on the dissy cap has to be near the firewall?
I would have thought you could make number 1 anywhere you liked once the dissy was dropped in at TDC and the rotor was pointing to a position with the points just starting to open.
Just wondering in case I have missed something
Gary - 1958 Star Customline and 1940 Ford Deluxe Hotrod
aussiebill
Posts: 1.8K,
Visits: 11.4K
snowcone (2/26/2012) Is there any particular reason why number 1 on the dissy cap has to be near the firewall? I would have thought you could make number 1 anywhere you liked once the dissy was dropped in at TDC and the rotor was pointing to a position with the points just starting to open. Just wondering in case I have missed somethingGary, you can have it pointing anywhere providing no1 tdc and rotor is firing at that plug lead, the fire wall makes a good reference point, but is generally either side of the clip.
GREENBIRD56
Visits: 102.7K
I don't know where they are "supposed to be"......but if you can end up with number one at front / right center aimed toward the upper radiator entry - then the plug wires are "biased" toward the loom they must enter to go to the LH bank and the RH bank. So 1 - 2 - 3 will be roughly to the passenger side and 5 - 8 - 6 will be on the driver side. Only number 4 and number 7 will have to cross to the loom on the other side.
Steve Metzger Tucson, Arizona
snowcone
Visits: 5.9K
That's exactly where I have put them.
It was easier to just put no1 at the front and work from there
