See all matches
Y-Blocksforever Forums
columbus y-block shootout
  • By Nathan Soukup 15 Years Ago
    Hey Stan ,I love the GASSER!Could you give us the specs on it?
    55 fairlane gasser 312 /c4, 57 f100 292/c4, 52 mainline gasser 302/t10 4speed
    By Ketterbros 15 Years Ago
    Brother and I are with Mr. Soukop, think n maybe saw a very similar car run at Greater Pittsburgh Dragway, or Keystone..Great Gasser look..
    Brother and I own/operate 1957 Ford Fairlane 312/4x2 and two 1963 Falcons 302 rollers carburated 600cfm, FE427 sitting in shed..
    By MoonShadow 15 Years Ago
    Brother and you missed this year. Breakfast was not the same! Only had Tony and Charlie and that plumber family. Chuck
    By Y-Block Stan 15 Years Ago
    for Nathan and anybody else, It's a 55 club sedan that was butchered beyond belief! It has an econoline front axle cross steered by a stock 55 ford box with a street rod manufacturing disc brake kit. stock bore 292,stock rods, crank,G heads,isky cam and kit,mallory dist. firing a msd 6al box and accel super coil.Stock henry rockers and stands with Isky pushrods.Quick time bellhousing and flywheel, zoom clutch with a 11" kevlar disc in front of a wide ratio toploader with a NEW Hurst super shifter 3.( Had all I could stand from the shifter that was in for columbus). Denny's heavy duty driveshaft, 9" 57 ford housing with posi and 4.56 gears and S&W race cars gasser bars. The front clip is fiberglass and was race weight when I got the car. It was cleverly mounted so as to fall off on the ground when opened. I don't have any Idea who made the front clip and I can't say I have ever seen another one, I am sure their out there but i don' know where.Stan
    By JimNolan 15 Years Ago
    I'd like to thank Bob Martin and John Gambill for donating the purse for the 57 Ford Shootout. I emailed John last week thanking him and I posted a thanks to Bob on 57fordsforever web site but it dawned on me this week that Bob might not visit that site. Bob, I appreciate your help starting Thursday evening when you saved me 75 dollars from the get go. I had a really good time and and I'm sure Tom Drummond, Larry Nicolson and Al White did also. Next year if the power brake vacuum line don't break off maybe I'll last a little bit longer. Jim Nolan
    Jim Nolan
    Thanks a bunch Stan,love the car!I have two cars thatare similar to yours.I have built a few with that Econoline axle.I use the same steering with stock steering box with good results.I discovered that I could use Aerostar rotors to fit the Econoline axels with a bearing spacer.
    By pegleg 15 Years Ago
    If all these gassers and cars showed up at Columbus together one year, there wouldn't be enough room for the Mustangs. We got Charlie to bring the truck (it's real, and it BOOGIES) now it's time for the rest of you guys to step up. Ray, Miker, Nathan, TIM, etc..............BigGrin
    By Canadian Hot Rodder 15 Years Ago
    Stan I LOVE your car!!!!  I keep thinking sometimes I might sell my Vicky, so I can build a Gasser like yours!  Hopefully I can make it next year to see the car in person! w00t
InstantForum 2014-2 Final © 2026
Execution: 0.000. 2 queries.
Loading
