Visits: 403
I put pressure to the system today after pulling the plugs. Nothing new. Also took the valve covers off - everything looked great - see my previous post. I dug out the compression test gauge today and tested it. Tomorrow I am planning to isolate the block by capping off the radiator hoses and filling the block with water and pressurizing it again. I'll turn it over by hand a few revolutions and see if there is any water around the spark plug holes or anywhere else. Then I'll do the compression test.
Visits: 31.8K
I think that’s all perfect, when you turn the key to strart you won’t have any surprises no need to rush thank you for the update
